LED Christmas Tree
LED Christmas Tree
A nifty little LED Christmas tree made from nothing but LEDs, resistors, and a found power supply.
Step 1Parts
Parts
This tree has made of 17 Red, Green and Yellow LEDs - the cheapest the electronics store had in stock. (no idea what manufacturer)
Their specs: (same for all colours)
forward voltage drop = 2.0V
max continuous current = 15mA
If you can, try to get LEDs that have the same specs - it's easier to design your tree.
The power supply used is from an old printer found out on the street - any sort of DC power supply will do, but the higher the voltage, the better. The one I am using supplies 30V, at up to 400mA. Enough power for 300 LEDs, but that's overkill. :-D
13 comments
Feb 23, 2010. 9:13 PMashcooper says:
Nice instructable.
i am very new to Instructables and my electronics knowledge is very basic.  I need to make a circuit of 150 LEDS.  But the distance between each LED will vary with the smallest distance being around 5cm and the greatest distance being about one metre.  When you say:
Try not to make the distance between connected LEDs any more than twice the distance of the LED's leads, or you'll need to use extra wire (complicated)
Is there somewhere you can point me online where I can see what you mean?  How complicated is it and will it make it extremely difficult if the distances between the LEDS varies?
I want to use a 12v power supply, not a batteries.  Maybe LEDS are not the way to go with this project?
Feb 24, 2010. 2:58 PMashcooper says:
Thanks for the reply.
OK, so I can have a single 12V power supply with multiple chains in parallel circuits running from it.  I just need to do the math or...
I will use http://ledcalculator.net/ to design the circuit and ensure that I have the specs of the LEDs correct to limit problems with blowing the LEDs or them getting too hot etc.
My question is whether or not there is any loss in power if I am wiring the LEDS one metre apart?  Will I have to take into account current (?) loss over the length of the wires? Or is the loss minimal?
As I am trying to wire a lot of these things over a 5 x 5m wall at varying distances I am assuming that the length of the wires will come into play when doing the math for the circuit(s) design.  But maybe I am wrong?
Sorry for my ignorance and thanks for your help.
Mar 22, 2008. 4:11 PMimarzouka says:
You can also use this calculator
Dec 17, 2007. 6:09 PMT3h_Muffinator says:
Nice! Reminds me of my first instructable!
Dec 17, 2007. 8:12 PMT3h_Muffinator says:
Yep, mine's all in parallel. I actually do have a resistor for ever LED; they're in parallel, and I have 3 strings of LEDs, so there's 3 resistors (which are all made up of two resistors each). I take care of the slightly different voltage drops w/ different resistor values, and each string is only for one color (green & blue values are so close I counted them as one). Definitely make a 3-D version! it's awesome!
Dec 17, 2007. 3:02 PMzjharva says:
i had been thinking about making something like this for a while. Nice instructable!!
Dec 17, 2007. 12:58 PMKiteman says:
Very nice, and versatile, too - it could be re-shaped to match almost any festival for any religion that celebrates light (Diwali, Hanukkah, etc)
Dec 16, 2007. 5:53 PMGorillazMiko says:
another instructabler posted something like this, but his was WAY too hard! great instructable! (favorited)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:MrTrick
