Step 4The Jig is up!
To overcome this, I used a jig - print out your design (or hand-draw it), and glue it to a scrap piece of wood, at least 5mm (1/4inch) thick. If you have a smooth wood like pine or MDF, you could just draw directly on it.
Find a drill bit the same size as your LEDs (3mm or 5mm, usually), and drill a shallow hole where each LED should go. Ideally each LED will fit snugly into the holes, without wiggling around.
Add Comment
