3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Computer Case Lighting
I wanted to make my computer case light up, but after reading some bad reviews on cold cathode lights I decided to make my own LED lights instead.
These lights only cost me about $15 to make. I had most of the materials on hand though. The only thing I bought was the LEDs and the drivers.
Custom LED bars for a computer case.
6 Watts of Blue LEDs
300 Lumens
Step 1Parts & Tools
Parts & Tools
Parts:
6x 1W LEDs
2x 3x1W LED Drivers
28" of 3/4" x 1/16" 90 Degree Angle Aluminum (could use 1/2" x 1/16")
Molex Connector
Wire Scraps (about 4 ft.)
4x Pop Rivets
Super Glue
1/8" Expandable Sleeving (optional)
Heat Shrink (optional)
Tools:
Soldering Iron
Drill
Hot Glue Gun
Wire Cutters
Needle Nose Pliers
Pop Rivet Tool
14 comments
Jan 30, 2012. 9:05 PMDemonDan_666 says:
great 'ible def gonna try it on my ThermalTake Armor :D
Nov 12, 2011. 9:27 PMbjamiel says:
cool ive always wanted to try doing this but im more of a software modder not hardware modder
Sep 4, 2011. 6:17 AMjoshua2397 says:
Is that the Haf X from CoolerMaster?
Jul 5, 2011. 10:29 PMjtc10512 says:
DAMN THOSE ARE BRIGHT!!!! Where did you get those? They are awesome. :D
Jun 21, 2011. 6:08 PMElectricFeel says:
Pretty good. You could also use EL Wire, which would give you a similar effect, but not have the negative effects that cathodes have. For a look at what Electroluminescent Wire is.
Jun 24, 2011. 6:56 AMElectricFeel says:
You're right in a way. EL Tape is not going to be as bright as EL Wire, but it gives off more ambient light around it. If you use EL Wire, you want that to be seen, rather than hide it in the case. EL Wire looks great around the case as well.
Jun 23, 2011. 8:30 PMalex the fisherman says:
i have that same case and it already has blue led's
Jun 23, 2011. 6:56 PMnico84 says:
sweet ill see if i can do that with my pc :)
Jun 17, 2011. 12:00 PMivondudley says:
That's pretty awesome, I like it
Jun 15, 2011. 12:09 PMzazenergy says:
This is a really great idea. If I had a tower I'd probably try to make similar LED case lighting for it!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:rocketman221
I enjoy building electronics & robots. I like building computers as well as writing programs & web sites. I like to build and launch rockets. I especially like to play with high voltage power supplie...
more »
