LED Computermouse Light
2,550
6
5
Published
Introduction: LED Computermouse Light
You can use an old computermouse and turn it into a cool light! Really geeky - isn't it? :-)
Sorry that I don't have more pictures for the single steps, because when I made this, I've never heard about instructables.com - but I hope you get the basic idea and it's a real simple project, so it shouldn't be a problem to make your own LED computermouse light.
And it's my first tutorial.
Step 1: The Parts You Need
You'll need:
Components:
a LED (3 mm) with your favourite color - I used a white LED from the German store http://www.led1.de with 12.000 mcd
a resitor - depending on your LED - calculation at the next step
a switch
batteries - i used two 1,5 volt AA batteries
a battery clip - to hold my two AA batteries
Tools:
hot glue
soldering-iron
screwdriver
driller
Step 2: Calculate the Resistor
I wanted to use two 1,5 volt AA batteries. My LED needs 2,95 volt - so there are 0,05 volt left for the resistor. The LED needs 20 mA.
When you buy a LED you'll see UF for "U Forward" and IF for "I Forward" - these are the values you'll need.
So let's calculate the resistor:
R = U-Resistor / I-LED
R = 0,05 / 0,02
R = 2,5 Ohm
So therefore I used a 2,2 Ohm resistor.
Step 3: How to Build
First I unscrewed the mouse and removed all those electronic parts. Then I removed the mouse wheel and drilled a whole which was big enough for the switch and glued the switch. Next I replaced the cord and glued the LED there. Then I connected the parts (switch, battery clip, resistor, LED) together - look at the picture.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    5 Comments
    Nice idea! At first I thought this was for a working mouse, one that you could use during the time the mouse is in use or not. Might give me an idea... Nice job, +4.5/ 5 stars.
    ooooooooooooooo
    nice, but i bet you could have do it on the mouse button
    man that's such a good idea! I didn't even think about it! *OMG* thank you for that comment! oh i think another dead computermouse would be modified into a light! maybe one of those two colored LEDs. i have two mouse buttons - when I press the right button maybe green light and when I press the left button then maybe red light! very nice idea - I think i should make this!
    i will try to, i have a becolor(right/green) led but pressing both button would make a short, so watch out. got 100 for 10$ on ebaaaayyy!
