Step 11Finalizing Battery Pack
It is important that the wire coming from the long lead of the LED goes to the Negative terminal on the battery because if you get the switched around the LED will not light.
Once you have the wires soldered to the Battery you can push the batteries all the way into the lighter taking care so that you push them in evenly now that they aren't taped together so we don't break the solder joint at the other end of the pack.
Depending on how much of the Divider you were able to remove earlier will denote how far in you can push the batteries.
NOTE: Once those batteries are in there you cant get them out without damaging them so make sure your light works before you push the batteries all the way in.
comments
Add Comment
Add Comment
