Step 12And You're Done
At this point you could glue the bottom of the lighter back on, I didn't as I didn't think ahead and I tossed the bottom piece out after I cut it off.
SOME SIDE NOTES:
After doing this I figured there were a few small things you could do to round out the look.
First you could colour the LED or get a yellow/orange LED to begin with so it has the Lighter look to it but I wanted it more as a flashlight.
Second if you feel like it you could use a small piece of shrink tubing on the wire that is soldered to the Long LED lead at the solder joint so that it insulates and you can put the striker wheel back in and not worry about shorting anything by accident.
Please leave comments and suggestions as this was my first instructable and I hope it will not be my last.
and wich battery goes to which contact of the led
And yes I soldered the wires to the battery, when doing this be very careful not to get the battery too hot as this can cause some problems. If you are not confident in soldering the wires to the battery you can try a conductive adhesive.
C,mon
Cheapskate
:p
