Introduction: LED Cube 3x3x3 With Arduino
Picture of LED Cube 3x3x3 With  Arduino
In this tutorial I’ll show how you can create your own LED Cube 3x3x3
Parts required:1x Arduino
27x LED's
9x 220 ohm Resistors
3x NPN Transistors (for example: 2N2222, BC547, 2N3904)
Wire
Step 1:
Picture of
Step 2:
Picture of
First, you will need a piece of cardboard with 9 holes as shown above. Place 9 LED's into the nine holes so that their negative leads(the shorter lead on the flat side of the LED) are all facing the outside of the square and bend them down so that they are all touching. Solder all of the leads together and remove the LED's from the cardboard to make one level of the cube. Repeat three times. Each level of LED's should have all of the negative leads soldered together with the positive leads sticking downwards.
Step 3:
Picture of
Now you will need to stack all three layers and solder their positive leads together. You may need to bend the leads inwards and play around with it to get each layer's leads to touch. When you're done, you should have every LED's negative lead connected to the negative leads of all of the other LED's in its layer while every LED's positive lead is connected to the positive leads of all of the other LED's in its column. Make sure that no positive leads cross with negative leads or you could get a short circuit.
Step 4:
Here is code
void setup() {
for (int i = 1; i <= 9; i++) pinMode(i, OUTPUT); for (int i = 10; i <=12; i++) digitalWrite(i, HIGH); } void loop() { int del = 100;
//flashes LED's from top to bottom for (int i = 0; i <= 3; i++) { for (int i = 0; i <= 10; i++) digitalWrite(i, HIGH); for (int i = 11; i <= 13; i++) { digitalWrite(i, LOW); delay(del); } for (int i = 11; i <= 13; i++) { digitalWrite(i, HIGH); delay(del); } } //flashes LED's in a downwards spiral for (int i = 0; i <= 10; i++) digitalWrite(i, LOW); for (int i = 0; i < 3; i++) { flash(del, 0, 0, i); flash(del, 1, 0, i); flash(del, 2, 0, i); flash(del, 2, 1, i); flash(del, 2, 2, i); flash(del, 1, 2, i); flash(del, 0, 2, i); flash(del, 0, 1, i); } //flashes LED's in one random column from top to bottom for (int i = 0; i <= 9; i++) { int x = random(3); int y = random(3); for (int i = 0; i <= 2; i++) { flash(del+50, x, y, i); } delay(del); } //randomly flashes LED's for (int i = 0; i <= 200; i++) { int x = random(3); int y = random(3); int z = random(3); flash(10, x, y, z); } //flashes LED's from one corner outwards for (int i = 0; i <= 3; i++) { flash(2*del, 0, 0, 0); for (int i = 2*(del/7); i >= 0; i--) { flash(1, 0, 1, 0); flash(1, 1, 1, 0); flash(1, 1, 0, 0); flash(1, 0, 0, 1); flash(1, 0, 1, 1); flash(1, 1, 1, 1); flash(1, 1, 0, 1); } for (int i = 2*(del/19); i >= 0; i--) { flash(1, 0, 2, 0); flash(1, 1, 2, 0); flash(1, 2, 2, 0); flash(1, 2, 1, 0); flash(1, 2, 0, 0); flash(1, 0, 2, 1); flash(1, 1, 2, 1); flash(1, 2, 2, 1); flash(1, 2, 1, 1); flash(1, 2, 0, 1); flash(1, 0, 0, 2); flash(1, 0, 1, 2); flash(1, 0, 2, 2); flash(1, 1, 0, 2); flash(1, 1, 1, 2); flash(1, 1, 2, 2); flash(1, 2, 0, 2); flash(1, 2, 1, 2); flash(1, 2, 2, 2); } } } void onOff(boolean state, int x, int y, int z) { //turns on or off led at (x, y, z) if (state) { digitalWrite(z+11, LOW); digitalWrite((3*x)+y+2, HIGH); } else { digitalWrite(z+11, HIGH); digitalWrite((3*x)+y+2, LOW); } } void flash(int msec, int x, int y, int z) { //flashes led at (x, y, z) on and off for msec onOff(true, x, y, z); //milliseconds delay(msec); onOff(false, x, y, z); }
Step 5: Code
evilcat made it! (author)2016-10-30
Nice project .Thank you!!!
garimagarga (author)2016-06-27
please tell me the connections of transistor
JoséM88 (author)2016-06-01
my middle leds work very weak but the center works well. do you know what to do ????
JoséM88 (author)JoséM882016-06-01
my voltage is 5v
alikarkuki (author)2016-05-20
Yas you can
JoséM313 (author)2016-05-19
can i use another NPN Transistors beside these ?
About This Instructable
9,275views
70favorites
License:
More by alikarkuki:Arduino Lcd Counter  arduino  capacitances measureArduino Relay Circuit
Add instructable to:
