64 LEDs makes up this 4 by 4 by 4 cube, controlled by an Atmel Atmega16 microcontroller.
Each LED can be addressed individually in software, enabling it to display amazing 3d animations!
8x8x8 LED cube now available, by popular demand:
http://www.instructables.com/id/Led-Cube-8x8x8/
Remove these ads by
Signing UpStep 1What you need
Knowledge list:
- Basic electronics and soldering skills
- Know how to program an AVR microcontroller - I will not cover that in this instructable.
- Protoboard. The type with copper circles.
- Atmel AVR Atmega16 microcontroller
- Programmer to program the Atmega16
- 64 Leds
- 2 status leds. I used red and green. (optional)
- Max232 rs-232 chip, or equivalent.
- 16 resistors for leds. (100-400ohms) will get back to this.
- 2x resistor 470 ohm. for status leds
- 1x resistor 10k
- 4x resistor 2.2k
- 4x NPN transistor BC338 (or other transistor capable of switching 250-ish mA)
- 1x 10uF capacitor
- 1x 1000uF capacitor
- 6x 0.1uF ceramic capacitor
- 2x 22pF ceramic capacitor
- 1x crystal 14.7456 MHz
- 2x tactile button
- optional pwr switch
- connector for 12v power
- optional connector for 5v power
Although when you connect the AC power supply, you can clearly see the brightness difference (The AC/DC outputs 5.5V).
What's the JP2 on the scheme please, i can't see on the picture?
Thanks
friend can you give us 8x8x8 led cube schematic and the code?
please
please please?
you are a grate man
thanks for the 4x4x4 cube
Also I have omitted the circuitry for IC2 & IC3 as they were not necessary.
If anyone can help, I'd appreciate it greatly.
Also...check it out!
http://www.youtube.com/watch?v=OZ35wkChIos
Also, if anyone wants the schematics, I created some.
Schematic:
https://docs.google.com/leaf?id=0BzXyjatQnrrLNDlmZmNlYmMtY2MyNy00OWQ4LWIyNTItNzliYTJlMDFmYTMw&sort=name&layout=list&num=50
Board:
https://docs.google.com/leaf?id=0BzXyjatQnrrLYTJmZjVkZmUtOTg1Yy00NjkwLTliMTYtMTVjNTBmODFmMTQy&sort=name&layout=list&num=50
You'll also need the "con-dinkle" library for one of the connectors I used for the main power terminal.
A large zip file of libraries can be downloaded here (the con-dinkle library is under the 'connectors' sub folder):
https://github.com/niccodes/Eagle-Libraries
Board: http://tinyurl.com/3gge58s
Schematic: http://tinyurl.com/3hs9vdl
And don't forget you'll also need the "con-dinkle" library for one of the connectors I used for the main power terminal.
A large zip file of libraries can be downloaded here (the con-dinkle library is under the 'connectors' sub folder): https://github.com/niccodes/Eagle-Libraries
Please remember that this is not my schematic and all commercial rights still belong to chr as far as I know. I don't believe he's have a problem with people selling one-offs, but I imagine production line copies are prohibited.
I can't seem to get to the schematic and board (assume it's Eagle).
Can you email me the files?
Thanks,
Randy Ray
vendor@randyray.com
thanks !
Here is our first try. We made our own PCB rather than using perf-board.
We are now building an 8x8x8 cube with home made PCB's as well.
Thanks chr!
http://www.ebay.com/itm/270844900187?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
-BB
