LED Dawn / Sunrise Alarm Clock, Nightlight & Security Light - Arduino Compatible by Ugifer
Featured
As the nights gradually lengthened in autumn 2011, I discovered the joys of Arduino and thought that it would be a great way to implement something that I have wanted for a long while - a gentle way to wake up on a winter's morning.  Sadly, it has taken me over a year to find the time and understanding to put it all together, but here, in time for some of the shortest days of this winter, are the results!
The idea is that getting up when it's pitch-black is a wrench.  Equally, having a timed light that just switches on all of a sudden is a shock.  What you want is a gentle ramp of light from imperceptibly dim to ragingly bright and ideally going from a nice gentle red to blazing white so that your brain thinks it's time to start that melatonin level rising.  My solution is a full-function micro-controller, RTC alarm-clock with the following features, among others:
Arduino compatible ATMega328 controlled, open, hackable, reprogrammable.
Battery backed-up RTC
Brightness-controllable red LED display
Cool rotary encoder input
Up to 18W LED dawn light
8-channel PWM light control (2 x 3W RGB + 2 x 6 x 1W white)
Exponential brightness ramp on dawn light
7 independent dawn alarms stored permanently in EEPROM
Alarms setable for any day, for every day, for mon-fri or for sat-sun.
One-press "arm/disarm" with indicator (stored in battery-backed RTC RAM)
Each alarm has optional buzzer
Escalating buzzer tone
Snooze function on buzzer
Controllable "ramp" time (min to max brightness time)
Controllable "hold" time (time at max brightness)
Controllable "buzzer delay" (time between max brightness and buzzer)
Easily controlled "Night Light"
"Security Light" mode (mode stored in RTC battery-backed RAM so safe to blackouts etc).
A dawn clock aims to wake you up gently and you can buy them commercially, but they are expensive, generally just white, not very flexible, and just not much fun!  We'll aim to make a full-feature dawn alarm clock and add a buzzer too, just to be sure we actually get to work on time!  It's also something of a learning exercise for me so it has a whole bunch of different interface and control techniques for me (and perhaps you) to master along the way.  There's about 6 separate projects in here and I'll try to put some example code in so that you can try them separately if you wish.
Although you could do this project perfectly well on a "real" Arduino, and indeed it was prototyped with a "nano" on a breadboard, I'm making the dedicated installation on a minimal Ardu' compatible so that you don't need to commit your "real" Ardu' to the clock.  I have made this project both on bits of perf-board and on a dedicated PCB that I have designed & had fab'd.  We'll look at both ways to do it - the result is much the same but the PCB is much less time consuming.
There are several discrete "sub-projects" that I've called "modules" in this project, any of which could be made and used individually:
The Arduino clone & RTC
The Digital time display
The Rotary encoder & switch controls with de-bounce.
The "Shift PWM" LED driver board
The lamps themselves & a trivial "buzzer" alarm.
Controlling an ATX power supply for efficient powering of the device
I've tried to make this instructable modular so just skip over any modules you can handle yourself already or use just one or two parts for your own project.
Step 1: See it Working - plus some Shameless Groveling
This is the finished and functional clock in action - the alarm is set to come on at 14:40 (if I could get up at that time I wouldn't need this clock!) and I have set it to ramp up over 1 minute (normally you would use 10-30mins but it makes a rather dull video).  You will see that every few seconds the lamp gets brighter.  The ramp-up and colours aren't very good in the video but you get the idea.  At the end of the ramp-up, the lamp stays on but the alarm sounds (you might normally have a delay but again, it makes a rather dull video).  I press to snooze the alarm, and then again to cancel the light and reset.
Shameless Groveling:
I've entered this 'ible into the "Glow" contest so if you like it or any of its modules then please consider voting for it.  I could have split it into a few entries but really it's more sensible all together and it's taken a year to get together. So if you like it, please....
Vote for me and help me get me some more fun stuff to make fun instructables with!
Cheers
Ugi
Ugifer (author) says: Apr 13, 2013. 2:17 AM
Hi Labrie
If you read the very end of the very last step, there is a special offer - I offered the first two people to ask a free board and set of ICs. You are the second person to ask so I will happily send you a set for free (including pre-flashed '328). You'll have to provide the other components like the 1W LEDs, power supply and standard parts.
I'm just back from vacation today so it will take me a few days to sort myself out but send me a pm and I'll sort something out for you asap.
Maybe you could also let me know in your PM what issue you're having with the code and I'll see if there's been an cut/paste error or something somewhere.
Cheers
Ugi
Labrie says: Apr 13, 2013. 2:00 AM
HI Ugi
Im having issues verifying the final file in arduino 22. do u have a later version .ino file
Or do you have any boards and programmed atmel chips available for purchase?
darkrayver014 says: Apr 6, 2013. 11:13 PM
could you make another of this without arduino.
i would like to make a nightlight with 25W CFL plus an alarmclock using LDR
Ugifer (author) says: Apr 7, 2013. 9:38 AM
This specific project culd not really be done without a microcontroller. However, there are other dawn alarm clock projects that might help you more. Search for sunrise alarm clock in the search box and pick those aspect sfrom each that are most like the project you envisage.
Thanks for reading &commenting.
Ugi
Akkord64 says: Feb 17, 2013. 5:35 AM
Good job on documenting this project. I am also making a sunrise clock and it will be my first Arduino project. I selected 50W LED's, and wanted to ask how bright your setup is (9W or 18W depending on yours shipment) on the white led side. Do you wish you had more wattage?
Ugifer (author) says: Feb 17, 2013. 12:35 PM
Thank you for your comment.
I have run this on both 9W and 18W and certainly with 18W it really lights up the room. It's maybe equivalent to having three 50W halogens pointed up at the ceiling so even though it's the other side of our bedroom, the whole room is bright.
My main aim with this was for it not to feel like the middle of the night when you wake and even at 9W that works pretty well. It's perhaps not blazingly bright on 9W but it's enough to make a real difference. You might argue that 9W is not quite enough but for me, 18W is plenty.
With 50W, you are going to have stacks of light. You might want to build yourself a programmable maximum brightness in the firmware, or perhaps ramp it up over slightly longer than I have because I reckon that much light will wake you before it gets to 50% intensity!
Would love to see some pics of your project when you get it finished.
Ugi
hilukasz says: Jan 10, 2013. 2:08 AM
this is genius. great work.
Ugifer (author) says: Jan 10, 2013. 2:35 AM
Thank you - it was certainly a considerable learning experience but there are lots of aspects that I have already found useful in other projects.
Ugi
hilukasz says: Jan 10, 2013. 8:09 AM
yeah I really want to do it just because of the DIY arduino. looks like fun project.
Ugifer (author) says: Jan 10, 2013. 12:42 PM
Did you read right to the end? ;-)
eyesee says: Jan 10, 2013. 5:50 AM
good
Ugifer (author) says: Jan 10, 2013. 6:47 AM
Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
