LED Daytime Running Lights Installation
Introduction: LED Daytime Running Lights Installation
Daytime Running Lights, also known as DRL, are devices in front of a vehicle that switch on whenever a vehicle is moving forward. These LED lights are universal fit so they can fit any vehicle. LED lights create a uniform projection that that ensures maximum output and visibility, making LEDs highly efficient. Together with the clip-in bracket that is very simple to mount, installing new LED Daytime Running Lights is an easy task that doesn’t take up too much time.
This guide explains how to install universal fit LED Daytime Running Lights on any vehicle. Installation is fairly straight-forward and simple to attempt.
Step 1:
Insert the wire into the bracket.
Step 2:
Mount the bracket. Since this is a universal fit Daytime Running Light, you can mount it anywhere you prefer. In this location we have mounted it right under the lower bumper.
Step 3:
After mounting the bracket, you can lock the LED daytime running light on the bracket.
Step 4:
After you mount the LED Daytime Running Light using the bracket, connect the wires and route the wires up and near the battery/fuse box.
Step 5:
Use zip-ties to tie the wire along the bumper.
Step 6:
Find the ACC in your fuse box and tap the red wire there. You can find the ACC location with an electronic meter by clamping the black wire to the battery negative or the ground. Insert the tester pen into the open fuse box into any unoccupied slot and remember the locations where the tester pen doesn’t light up. Start the engine and test on the spots that didn’t light up. Find the spot that lights up ONLY when the engine is on. This is the ACC spot.
Basically, when the engine is on, the indicator lights up. When the engine is off, the indicator is also off.
Step 7:
Once you find the ACC location, you can tap the red wires to the blade of the fuse and insert it back.
Step 8:
Tap the black wire to battery negative.
Step 9:
The pictures in the installation guide easy to follow on installing LED Daytime Running Lamps. Installation is not at all complicated, but actually quite effortless. Here are a few more photos of the LEDs.
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
  • Pocket-Sized Contest
Another error:
many ones did this wrong: your DRL should be about same position (wide) as car's head lamp. For obvious safety reason.
The position you installed won't pass inspection in EU (because I tried and failed to pass)
Hello! your DIY spirit is good but: this is not gonna go through annual inspection (at least in EU) and it is potential dangerous in electrics (if your lights get shorted in humid/raining weather what do you expect to happen?)
according to regulation (at least in EU), the day time running lights should turn off when other lights turned on (low beam, high beam, fog lights etc).
So, please do not connect your lights according to this article, whatever reason it is, your car is not for experimental tool and you won't pass inspection in EU.
this method does not wire them correctly, DRLs should turn off when sidelights/position lights are turned on a crossover relay needs to be placed that does this
You are right, that requires 3 wires from the box, but my DRL control box only comes with 2 wires, i have no choice.
wrapping a wire round a fuse is mega dangerous cut a wire and solder it together properly
Thanks for your suggestion. We can also make a fuse splitter and connect the wiring from there.
Your car looks nice !!!
