3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Deck Lighting- in color!
Step 5Connect wire through Posts
  • last photo ←
You will use the low voltage wire to connect the LED strips on either side of the post.  Push a section of wire, long enough to solder onto both ends of the strips, through the hole you drilled.  If the post is hollow, you can leave extra wire as it will make it easier to solder and you can just push the extra into the post.  If the post is hollow, you may need to use a stiff wire like a coat hanger to help guide the wire through (or put the wire through, tape the wire on, and pull it back through the hole).
Solder the low voltage wire onto the ends of the LED strips.  Make sure to go over all of your solder connections with silicon right away.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:usLEDsupply(usLEDsupply)
Greetings from everyone at usLEDsupply! Like many of you, we have realized that LEDs are awesome and we try to incorporate them into even the most unlikely situations. We have been working on a lot...
more »
