LED Desk Lamp
3,005
Posted in WorkshopMetalworking
Introduction: LED Desk Lamp
Useful LED Desk Lamp made from re-purposed flashlight, plumbing parts and 5 volt adapter produces excellent light for doing fine detail work.
Step 1: Start With Neck of Lamp
Obtain piece of chromed water supply line and bend into shape desired. Clean inside of one end with sandpaper or steel wool and tin with plumbing solder.
Step 2: Obtain Chromed Pan That Fits Underneath Electric Range Element.
After obtaining chromed pan drill hole which should be slightly larger than chromed water supply line diameter. This hole should be drilled on side opposite from cutout.
Step 3: Cut Piece of Copper Clad Circuitboard Material Into Square
Take piece of circuitboard material and drill hole in it larger than diameter of chrome water supply tube.
Step 4: Solder Board and Supply Line Together
Solder end of supply line and circuit board together with plumbing solder after liberally applying flux to board and inside of supply line. Apply hot melt glue over soldered connection.
Step 5: Push New Neck of LED Lamp Through Hole in Base of Lamp
After pushing new neck of LED Lamp through hole in base of lamp, glue circuit board to inside bottom of lamp base with hot melt glue and clamp together until cool.
Step 6: Base and Neck of Lamp Connected Together.
Base and neck of lamp should form strong bond and should look like this.
Step 7: Obtain Mini LED Flashlight and Cut With Tubing Cutter.
Mini flashlight should have bottom and battery case removed and using tubing cutter, should be cut approximately half way down.
Step 8: Keep the LED Part of the Flashlight.
The part of the flashlight with the LED's should be taken and a hole should be drilled in the side which is a couple of drill sizes larger than the outside diameter of the lamp neck. Save switch part for later.
Step 9: Neck Will Be Inserted Like This in LED Head.
Wrap a piece of thin carboard around end of neck to provide electrical insulation between LED head and neck of lamp.
Step 10: Drill Hole in Other Side of LED Lamp Head.
Drill smaller hole in other side of LED lamp head about the same level as the other hole. In this hole you will mount a nut and machine screw to which the negative power lead will be attached.
Step 11: LED Head Should Look Like This When Finished.
LED head will have the negative power lead attached to the machine screw and nut and the positive lead will be attached to the spring in the middle of the green circuit board.
Step 12: Obtain Metal Jar With Lid.
This metal jar was an empty cosmetic cream container which I re-purposed because of it's shape and nice silvery finish. A notch was cut out of the rim and finished with a small file. The notch was two times wider than the diameter of the lamp neck.
Step 13: Finished Jar Lid.
The finished jar lid should look like this after being finished with the file.
Step 14: LED Head Attached to Lamp Neck With Hot Melt Glue.
After putting insulating cardboard spacer around neck and slipping assembly through previously drilled hole in LED head, secure with a dab of hot melt glue. Wires can be around 15 AWG and make sure they are long enough. The negative is attached to machine screw and the positive is soldered to the spring in the middle of the circuit board as shown in picture. If you have access to a continuity tester or ohmmeter, check to see that there is no electrical continuity between the LED head body and the rest of the lamp body.
Step 15: Wires Should Be Pushed Through Neck of Lamp.
The wires should be pushed through the neck of the lamp and come out of the bottom like this.
Step 16: Jar Lid Should Be Attached to LED Head and Lamp Neck Like This.
The jar lid should be glued to the LED head and lamp neck like this with hot melt glue.
Step 17: Bottom of Cosmetic Jar Has Hole Drilled in It.
The bottom of the cosmetic jar should have a pilot hole drilled in it and an electrician's slug cutter should be used to make a large hole. The hole should be slightly larger than the diameter of the flashlight.
Step 18: Mount Cosmetic Jar Bottom and Switch Assembly on Hole in Lower Part of Lamp.
Bottom of cosmetic jar has switch portion of flashlight mounted on it and because the lower part of the flashlight has a threaded bottom, a bolt was found to fit it. After tightening, the whole assembly was fastened in place with two machine screws with nuts.
Step 19: This Shows the Proper Mounting From the Underside of Lamp.
After switch assembly is mounted in place, two holes are drilled through either end of cosmetic jar base and two machine screws with nuts hold it in place.
Step 20: Cut Piece of One Sided Circuit Board a Little Bigger Than the Rectangular Lamp Base Cutout
Then drill a hole in middle of board approximately 1/4 inch in diameter.
Step 21: Run Wire From Re-purposed 5 Volt Adapter Through Shiny Side of Board.
Copper board should be shined up with very fine steel wool 0000 grade preferred.
Step 22: Shiny Side of Circuit Board Is Used to Hide Cutout of Lamp Base.
Dull side of circuit board is glued to metal base inside base of lamp with hot melt glue.
Step 23: Positive Wire From Lamp Head Is Soldered to Switch Center Terminal.
Positive lead from adapter is soldered to body of switch assembly. Check with Ohmmeter or continuity tester that this switch when actuated, makes and breaks the circuit. A 7 to 10 ohm, 2 watt, voltage dropping resistor is then put in series with the incoming positive supply from the adapter and soldered to the other side of the switch assembly. The negative supply from the adapter is directly soldered to the negative lead of the lamp head. The wires are then held in place with hot melt glue. the resistor is needed to drop the 5 volts of the adapter to the 4.5 volts required by the LED lamp head so it will not be damaged by excessive voltage. Double check all electrical connections and plug in lamp and make sure it works before proceeding to the next step.
Step 24: Piece of Leatherette Is Then Cut to Size and Hot Melt Glued to Base of Lamp.
I hot melted a piece of leatherette to the base of the lamp and when dried, used scissors to trim around base.
Step 25: Completed Lamp Working
Plug in and enjoy your new lamp.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    This is a cool looking lamp. Nice work!
