LED Desk Lamps
LED Desk Lamps
What to do with discarded LED PCBs? Use them as desk lamps! Duh! A while ago I recieved these 12" strip PCBs with 30 high intensity LEDs on each. I took 4 and attached them to a board to see how much light they would emit together. Turns out that they put off what appears to be about the same as a typical 18 inch flourescent undercabinet fixture. I now have two that illuminate my computer desk.
Step 1Fabricate mounting board
Because these strips do not weigh much and also do not creat much heat at all I chose to secure them with cable ties. Also, I had these laying arround, so why not? I then took the scrap 3/4" thick board and measured to length and width and cut with a handsaw. I think the dimensions ended up being about 12" long by 6" wide. Lastly the mount holes for the cable ties had to be drilled. I drilled these a little narrower than the strips. One pair at each end.
15 comments
Mar 27, 2011. 11:46 PMfuzhouled says:
I have a better solution for the application.http://www.fuzhouled.com
Sep 24, 2010. 8:15 PMBogiDewd says:
I've been searching for a good solution to the flourescent bulbs I currently have, and this looks like a great solution.
Do you have any idea on the brand name the strips are (the part number appears readily available in your photos)
What about the part number on the power supply?
Nov 11, 2008. 7:06 AMEeeeeeeeeekz says:
wow very cool, thanks
Apr 1, 2007. 8:31 AMi make shooting things says:
these would never burn out right? how much dose it cost to make these? cool idea im always looking for a way to use reduce, reuse, and recycle.
Apr 1, 2007. 12:36 AMLasVegas says:
Oh... I didn't mention it before, but I think this is a pretty good Instructable. I'd appreciate if you could add a wiring diagram for the setup.
Mar 31, 2007. 10:58 PMtheRIAA says:
Im not one to cry code, but that pic in step 4 is pretty bad
Apr 1, 2007. 12:25 AMLasVegas says:
I'd cover the 20v bus bar as well. Just for safety's sake.
Mar 31, 2007. 8:55 PMLasVegas says:
You're calculations have a bit of a problem. You see, this is not entirely a resistive circuit since each 4 LED module has it's own regulator. I suggest that instead of calculating based on the total resistance, that you measure the total current while the unit is connected. Disconnect one leg of the secondary and connect that to the Multimeter's Amps connector. Then connect the common to the point the secondary wire was connected. IOW; The amp-meter is connected in series with the device. From this you can determine the Wattage. I expect it will still be very low, but not in the microamps range.
Apr 1, 2007. 12:18 AMLasVegas says:
I expect with 120 LEDs, you're probably pulling 4 to 6 amps @ 120V. Still significantly less than incandecent or even florecient. Note that your Lumins are probably rather low, but LEDs supply directional light so none is wasted directed the wrong way.
To get an idea about LED lighting and the currents used, check out C Cranes LED Light Bulbs.
Mar 31, 2007. 9:24 PMChavez says:
120 high intensity leds, a transformer, and four full bridge rectifers and resistors and you calculate 1 milliwatt!!!, without a schematic, I can not give you a good estimate but roughly you have 30 Watts or 30000 mW so you don't think it's a typo. would you agree with me LasVegas!! . clamp an AC current meter on one of the wires from the AC wall outlet and find out the rms voltage and let us know what you get.
Mar 31, 2007. 8:02 PMlawdog says:
Great idea. Where would one go about finding LED PCBs if they don't have them to begin with? I was thinking about mounting one behind/below my LCD monitor to create a desk light right onto the keyboard/desk.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sdallesasse
I am in my third year of my electrical apprenticeship. This is my second career; formerly I was in the firefighting / EMS field. I enjoy my work and am always curious about new hardware (devices, wi...
more »
