LED Doggy Lamp/Desk Organizer by Toglefritz
Contest Winner
Step 2: Drill Holes for the Bolts
I chose not to have the holes necessary for connecting the pieces of the Doggy Lamp cut by Ponoko in order to limit the cost of the order.  It is far cheaper simply to drill holes manually than have a laser cutter do it.  Plus, in case you have some spare nuts and bolts in your shop, you can drill any sized hole you need.
Holes will need to be drilled in the leg pieces, neck pieces, head pieces, body side panels, and ear pieces.  Take a look at the dimensioned drawings on this step for measurements of the desired hole locations.  The laser cut pieces will ship with an adhesive paper backing.  Do not remove this paper until all the holes are drilled because you can draw marks on the paper in order to locate the holes without messing up the wood.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
