3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Fan/Party Light
LED Fan/Party Light
Are you bored with dinner parties? Are you looking for a simple way to make your next get together a little snazzier?  Then this simple circuit is the project for you.
This instructable will teach you to create a mercury switch that will morph your ceiling fan from a dull wind machine into an LED light show. The basics are simple; turn your fan on and the lights will shine--pointed towards the ceiling or to the floor. Turn the fan off, and it's a subtle sign to your guests that they have eaten all of your food and drank all your boos, and it's time for them to head home.
There are a few different ways to achieve the party experience, depending on your intended level of awesomeness:
Three circuits on the fan
Just one circuit on the fan
Step 1Parts Needed
Parts Needed
This is a very simple project, so there are not many parts needed.
Parts:
4"x3"  Project Board (or smaller, I actually cut mine into three parts about to 1" x 3")
3 volt Button Cell Battery
Button Cell Battery Holder
Mercury Switch (tilt switch)
5mm LEDs (I used Blue, White, RGB, Blue Flashing)
Sticky Tack (blue gummy sticky stuff)
Tools:
Wire Cutters
Soldering Iron
Solder
Hack Saw (for cutting Project board)
11 comments
Oct 29, 2010. 7:52 PMMunchys says:
Tilt switch made without mercury http://www.instructables.com/id/Tilt-Sensor-cheap-easy-nontoxic/
Oct 9, 2010. 12:20 PMWesley666 says:
Good idea, bad tilt switch. You can get tilt switches that use a steel ball bearing instead of mercury, much safer.
Oct 10, 2010. 5:45 AMHarveyH44 says:
Yeah, was surprised to see that mercury switch, don't see them much anymore. For something like this, kind of risky. If the board flies off, and slung up against a wall or something, tiny pieces of glass is hard enough, but the mercury is even worse. Really bad for pets and small kids crawling around. The tiny amount wouldn't do much to an adult.
Oct 10, 2010. 11:21 AMWesley666 says:
Ya, I wonder where he got it from? I have to admit its cool looking though, I have a bottle of Mercury, about half a liter I have collected (Safely) from things over the years from anything that had Mercury in it. Its fun to look at but that's about all. Very heavy.
Oct 11, 2010. 7:40 PMAdam Manick says:
You can get them easily in old and thermostats
Oct 11, 2010. 10:00 PMWesley666 says:
I know that, where do you think I got half a liter of Mercury? (Thermostats and other places) What I meant is that Mercury isn't used in Thermostats anymore, old ones are somewhat hard to come by, and that they usually don't have the long leads like the ones in this Instructable, the ones the author uses look brand new.
Oct 9, 2010. 12:03 PMdark sponge says:
Clever, I like them!
Oct 9, 2010. 12:06 PMdark sponge says:
Also, you might want to balance it out by putting a counterweight on the opposite blade that the light is on. If the fan spins fast enough while out of balance it could shake unstablely and maybe do some damage.
I find these ceiling fans usually shake anyhow, at least mine does, so you could probably balance it using this.
Oct 9, 2010. 1:43 PMAngryRedhead says:
My ceiling fans don't shake, but we used small weights to correct any wobbles that were there. You can buy the weights in the lighting department at big box DIY stores.
Oct 9, 2010. 4:26 PMWesley666 says:
Ahh, ya, they are made to pivot and ours shakes a bit, you can see it, but this would balance it out, and would look cool too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
83
Author:seligtobiason(www.SeligTobiason.com)
Well, I feel like I am a pretty regular guy... I work in the Entertainment industry, right now am working for Lucas Animation on a Top secret assignment ;). I love to create things, and build things ...
more »
