LED Felted Star
Introduction: LED Felted Star
This is a fun little project - a guide to making an unusual decoration just in time for Christmas! I used handmade felt, but any fabric would do. The main feature is a colour-changing LED light in the middle of the star. I've used a technology called conductive thread, which looks and behaves like conventional sewing thread with the added bonus of being conductive, allowing the thread to be used in place of wires in electronic circuits.
The large lithium battery will last a very long time since the LED uses very little power and can be switched off when not in use. It's also surprisingly bright - bright enough that as well as being ornamental it could be used as a night light for a child, to find your keys or to dimly light a step to avoid anyone tripping in the night. You could also include a bag of potpourri, lavender or another fragrance and hang it up to scent your room.
Step 1: You Will Need...
You will need....
For the star:
Merino Fleece
Felting needle
Felting mat
Alternatively, you can simply choose a decorative fabric, but felt is ideal since it won't fray
Needle and sewing thread
6 inches of narrow ribbon or thin cord
Stuffing or wadding
Beads for decoration
For the LED circuit:
Colour-changing LED
Switched coin-cell holder
Conductive thread
Lithium battery
If you prefer you could use a Colour-changing LED kit - The kit, available from Kitronik.co.uk,  includes the following -
Colour changing LED
Conductive thread
Battery Holder
Lithium battery
You would also need a Sewable switch
Small pliers
Step 2: Making Your Felted Star...
Begin by making the front and back of the star in red felt, adding fine layers of blue and turqoise merino fleece to create a grading of colour at one side and working it in with a felting needle by placing the felt on the mat and stippling through with the needle to draw the fibres through the fabric and bind them together. The process of adding fleece to the base felt can cause it to stretch or contract, so it's a good idea to do this before cutting out your shape.
Next, make a small hole where the LED will be on the front, and add beads as further decoration. (Pictured - Front star with the LED in place in the centre)
Step 3: Adding the LED...
When you have completed this stage it's time to add the LED. The kit consists of a colour-changing LED bulb, a battery holder and battery and some conductive thread. I also used an on/off switch since the battery won't be accessible once the star is finished.
The bulb has two wires attached, the longer one is positive and the shorter is negative. Use a small pair of pliers to bend the wires into loops which will lie flat against the back of the fabric, making sure you remember which one is which!
Next, push the bulb into the hole from the reverse side and stitch it in place using one strand of the conductive thread around the positive loop and one around the negative, being sure to wrap the thread firmly around the wire several times to make a good connection. I didn't want the bulb to stick out too far on the front of my star so I used a scrap of spare felt to space it back from the hole a little.
Step 4: Adding the Battery Holder and Switch...
The next step is to add the battery holder and the switch to the back of the star, next to the bulb. Insert the battery and touch the thread to the terminal to check that your circuit will work - that part is fun, it's amazing to see what appears to just be silky grey thread causing a bulb to light up!
Using the thread on the positive side, stitch around to the positive terminal on the battery holder, again making sure the connection is good by stitching the thread firmly around the terminal several times. Repeat the process with the negative thread, taking care that the two strands won't touch each other once the pieces are sewn in place.
If you chose to use a separate switch, or add more than one light, the sewable circuit is very forgiving for non-electricians! Provided the positive thread connects to the positive terminal, the negative to the negative, and the two don't cross or touch, you can't go far wrong, but there is a nice neat sample of a circuit with a switch and two LEDs here.
Step 5: Final Assembly...
Once the electronics are in place, line up the two halves of the star and make a hole in the back piece to allow access to the switch. If you used a fabric which could fray you will need to hem around the hole or stitch it like a tiny buttonhole.
Add a loop of ribbon to hang the finished star, and sew the two sides together, stuffing the star as you go along but leaving a space so as not to obscure the switch.
Step 6: All Finished!
So there you have it, a unique handmade star to brighten up your home, or a very special Christmas present! This was my first Instructable, I do hope you found it helpful and easy to follow, and hope you have as much fun making this project as I did!
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
