3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Fireworks
LED Fireworks
Nowadays technology changed everything. Things that have been made many years ago are now appearing in a new form with new and modern parts.
So I decided to simulate fireworks with LEDs and made a machine that makes LED fireworks.
It works simple, there are a lot of LEDs that everyone is connected to a capacitor with a resistor, the machine charges the capacitors and a timer drives a motor that strews them around.
Step 1Things You Need
Things You Need
To make your own LED fireworks machine you need the following things and tools:
  • Some colorful LEDs
  • Some 1K resistors
  • Some 470uF capacitors (or higher)
  • Two plastic disks
  • Some screws with bolts
  • A long narrow plastic strip
  • 1x 1N4007 Diode
  • 1x 1N4148 Diode
  • 2x 100nF ceramic capacitor
  • 1x TIP122 transistor
  • 1x 50K potentiometer
  • 1x 33K resistor
  • 1x 100K resistor
  • 1x 100uF electrolyte capacitor
  • 1x 3.3uF electrolyte capacitor
  • 1x BC547 transistor
  • 1x 555 IC + socket
  • 1x Simple push button
  • 1x Small motor
  • 1x 9V battery + connector
  • Some wire
  • Foil
  • Drill
  • Screw drivers
  • Soldering iron
  • Soldering oil
  • Soldering wire
  • Glue
  • Pliers
  • Wire cutter
  • A bubble bag
  • Things to make a PCB (if you want to have a circuit board)
16 comments
Sep 11, 2010. 6:32 PMWeaponMaker96 says:
Sorry, wrong contest ;D
Sep 13, 2010. 6:00 AMsc7923a says:
I assume you're referring to your post in the wedding DIY contest, and I disagree! I've always wanted fireworks at my wedding but they didn't fit in the budget - now they do! :)
Sep 19, 2010. 4:24 AMagis68 says:
I Had fireworks and accidentaly burned my best man 's hair!!!!!!!!
Jul 3, 2011. 11:58 PMroland985 says:
nah, you'll just poke all the guest's eyes out...
Jul 4, 2011. 4:38 PMrcisneros says:
Damn. I was going to say that.
Oct 30, 2010. 8:30 PMsibuadvancetech says:
cool stuff!! thank you!!
Oct 12, 2010. 2:01 AMShanjaq says:
Maybe encase the cap/led/resistor modules in hot-glue to make them more durable and less of a danger to eyeballs =D
Sep 27, 2010. 7:41 PMjtmjr says:
i could have used this under my tables
I really like the looks of this wish i had seen it before our reception you got my vote :)
keep me in mind when voting i built the 3 tier fruit wedding cake
Sep 9, 2010. 5:32 PMcowscankill says:
Very cool! Would look like fireworks in the dark. One question: what is that song in the video? :D
Sep 25, 2010. 7:28 AMbr_amar says:
That song is from a bollywood movie called "DHOOM"
Here is the song:
http://www.youtube.com/watch?v=9uIz1DFNJnY
Sep 19, 2010. 4:31 AMagis68 says:
Very nice job and well presented. The white disks are handmade right? from what material? (I know are made from plastic) but i mean what plastic??? please give me a response maybe you find me a solution in a big problem with my old scanner!!! You will be my hero you know!
Sep 9, 2010. 11:40 AMElectronics Blurred says:
It's beautiful , thanks .
But i would have used a copper wrapping around the led's ,
or you could flip the led's to north direction and lay diffrent poles of copper wrapping , the copper is attached the output and input ;)
I didn't say you should have , i only said that i would .
Peace .
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
53
Author:vahid_you2004(Visit dihav.com)
I'm a mechanical engineer, and I like computer programming, mechanics, electronics and specially the robotics.
