LED Fuse Sparebot
Published
Introduction: LED Fuse Sparebot
Lets have some fun with LED and Fuse :D
Step 1:
Parts :
  • Bulb (use broken bulb because only need the base)
  • 3 pcs Fuse
  • 1 pc LED 10 mm (i use orange colour because i just have orange in my stock, better use white colour)
  • 2 pcs button battery
  • 2 pcs magnet
Tools :
  • Solder.
  • Pliers or Hammer
  • Small screwdriver
Step 2: Get the Bulb Base
Take off the bulb from its base.
The easy way to get the bulb base is break the bulb glass with hammer or plier, must be carefully with broken glass,Use goggle and glove for safety.
Clean the whole base using a small screwdriver.
Step 3: Finishing
After solder LED to bulb base, solder fuse to the bulb base too,
because magnet can't stick to fuse tip
solder some iron wire , from LED excess wire, to fuse tip
Stick magnet together with button bateries to fuse tip,
Now you can put this sparebot to metal,its will stick and LED will light up.
make sure (+) (-) of bateries
Step 4:
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    4 Comments
    sorry to say bro but Something missing between step 2 AND Step 3 ; that cannot explain correctly
