Remove these ads by
Signing UpStep 1Materials
- Old canning jars
- Old bottles (wine, beer, oil, vinegar, etc.)
- Old insulators
Other materials which we used:
- 5 RGB LED modules $3 ea (they can change color or be set on a solid color like white)**
- 22-4 Security/Control Cable $.25/ft to run between each light and to the power source.**
- 3M Scotchlok Waterproof Butt Connectors $.25 ea (4 for each light)
- 12V 12 Watt Power Supply $15 (Could also be Solar or a transformer)
- RGB LED Controller $20-$35 or none if you are just going to use white or single color modules/LEDs.**
- Wire strippers/cutters
- Pliers
- Hot Glue Stick + Lighter (or hot glue gun)
- Paper/Pen to Draw Schematics
- Tape Measure
- Drill (if you need to make a bigger hole for cable to go through light fixture)
**For this project, I chose to use color changing RGB LED modules because I wanted to create a fairytale like aura along the path. However, you could also do this project and use white or single color LED modules (which you could hook up to solar/battery instead of running wire between each light. However, for the RGB LEDs, running wire is necessary in order to control the changing colors through the use of one controller).**
comments
Add Comment
Add Comment
