3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Glass Tiles
LED Glass Tiles
I wanted to try something interesting while I was doing some bathroom renovations, so I put an LED strip behind the glass tiles I was installing. You can see more a the LED glass tiles on my website too.
Step 1Prep
Prep
I put a small hole in the wall and strung the LED strip wire from below with a wire coat hanger. I used the access hole where the sink drain pipe goes into the wall to feed the wire into.
11 comments
May 12, 2008. 4:02 PMPatrik says:
Looks great! I think a built-in LED border around a vanity mirror would be really cool too... I assume you've thought of this, but a quick caution to anyone who might want to follow your example: Make sure your LEDs aren't going to burn out after a couple of weeks of use, if you plan to build them into your wall like this! In particular, you may not want to do this with a cheapo Xmas decoration LED strip that is only made to last one season. For example, if the LEDs are in parallel in the strip, it is important that each LED have its own current limiting resistor, otherwise one might burn out and ruin the whole effect.
Oct 23, 2010. 2:44 AMDIY-Guy says:
Those LEDs behind the glass tiles are beautiful, just beautiful!
The SMD (Surface Mount Device) LED strips are usually intended for automotive lighting, or accent lighting inside a building. Most SMD LED strip specs that I've seen on the big auction sites do claim 50,000 hours life or something like that. Of course, who has 5.7 years to sit around waiting day and night to find out if the LEDs and resistors and every other component will last that long!
I would not hesitate to place one of the waterproof SMD LED strips with integrated resistors into a permanent installation such as this.
Nov 24, 2009. 10:26 PMthe_keiser says:
Now what would be an awesome upgrade to this is you use red and blue led's set up to sensors that when you turn on the cold only it lights up the whole row blue and vise-versa with red and when you mix hot and cold. a portion of the leds are blue and a portion of the leds are red. the more hot the more red and so on
Dec 25, 2008. 10:01 AMtallht says:
i think it's greater if you use more colors @!!!
May 12, 2008. 4:09 PMLinuxH4x0r says:
Nice! I'd diffuse it more though
Dec 18, 2008. 8:02 PMCat on my Lap says:
Maybe with some etching agent; frost it.
May 13, 2008. 5:46 PMLinuxH4x0r says:
Maybe I should try this in glass bricks
Dec 13, 2008. 5:16 PMzomfibame says:
that's a great idea.
May 13, 2008. 7:52 AMRobotic_mage says:
Great Job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:newtontroy
