Indications:
-This instructable requires some knowledge of electronics and auto body assembly.
-This might involve taking apart large sections of your car's console, if this could void a warranty, do so at your own risk.
-In some states and municipalities, it is illegal to have non-signal lights on while your vehicle in motion. Check with your local authorities before using on the street.
Time: 3-6 Hours
Cost: $20-50 (depending mainly on how many lights you get)
Difficulty: Decently easy
Remove these ads by
Signing UpStep 1Gather materials
-One or several waterproof, 12V LED strings - $10 ea.
-Lots of wire. Two-strand polarized wire is great (red-black or white-black)
-SPST switch - Free-$3 (I got a lit-when-on one)
-555 timer - $0.10-$1.50 if you went to Shady-o Rack
-10000-15000 uF worth of 10v capacitors (you can string them in parallel to add the capacitance)
-47uF capacitor
-100uF capacitor
-.01uF capacitor
-1.1kOhm resistor
-15kOhm resistor - the bigger the resistor the slower the pulse - alternatively you can use a potentiometer
-Project box of some sort
-Scrap thin medium-density fiberboard (MDF) or sheet metal
-Epoxy
-Electrical tape
Tools
-Soldering iron and solder
-Wire strippers
-Needlenose pliers
-Hot glue gun
-Power drill
-Various size drill bits
-Various screwdrivers
And of course a car. It's a good idea to know your way around the inside of your car a bit before beginning.
Make your car or motorcycle glow, can be mounted virtually anywhere, easy to install, 12v power required, connects to an accessory switch, cables included
Light Disc's low profile design is perfect for highlighting your cars interior - put it under your seats, dash, inside your speakers or anywhere else you choose.
Approximately 1" Diameter, 3/8" High
Light Disc easily connects to your vehicles 12 volt battery. Package includes: 1 Light Disc, wire, fuse casing and installation instructions.
Weather resistant for interior and exterior use
All 4 major colors...red,green,blue and multi.... Rick_kim25@yahoo.com
As far as sealant make sure it doesn't react badly to vinyl, some discolor it.
And that's my question, i have installed neons and not leds. can i somehow connects your "pulse generator" to my neons to have that effect?
thanks
thanks
the fire wall
they can be found at your local shady-o-shack : )
