1. I'm a nerd.
2. I wanted citrus plants but I live in an apartment with horrible "sunlight accommodations" in Iowa City, Iowa. Citrus plants require a lot of sunlight and this week alone it's been cloudy almost every day.
3. I live in a college town so anything left outside either gets stolen, broken or thrown up on so growing them inside is a must.
Those are my reasons, maybe you have a few of your own but before going any further I must say that if you're going to use this information to grow pot I will not be held responsible for your drug habits if you are caught. Like I said, I'm using this to start up my lemon, grapefruit and orange seedlings, which last time I checked was perfectly legal.
Referenced instructables:
http://www.instructables.com/id/Table_top_energy_seed/
http://www.instructables.com/id/Growing-Plants-With-LED-Lights/
http://www.instructables.com/id/Self-Watering-Plant-Container-out-of-a-2-liter-bot/
Oh and one of the battery terminals I used came from the design by xtank5:
http://www.instructables.com/id/Battery-Holder-Version-2/
thanks for that idea too!
Remove these ads by
Signing UpStep 1Materials
Materials:
25 x red LEDs (cheap ones off ebay, **see bottom for important details**)
5 x blue LEDs (same)
2 x ferrite beads
2 x 1K resistors
2 x 2N3904 transistors
28 gauge wire and some much thicker scrap wire that was lying around (the thicker wire is not necessary)
1 x perf board
Common materials:
1 or 2 Liter bottle
A gatorade bottle
electrical and clear tape
aluminum foil
pill bottle
cardboard
batteries
Tools:
Soldering iron and solder
Wire stripper (was helpful)
Knife or razor blade
Brain (also helpful)
**LED Info: According to Wikipedia, chlorophyll a & b absorb light at maxima of:
430nm & 662 nm for chlorophyll a
453nm & 642 nm for cholorphyll b
So make sure that you find blue (440490 nm) and red (~625-740 nm) LEDs that are as close to those maxima as possible!
Also, you will notice that there are many more red LEDs than blue ones, this is because I read that red LEDs are more important for flowering than blue LEDs (I was corrected, blue is for growth and red is for flowering) and many people are completely successful with red LEDs alone. Whatever you do, don't waste your money on green LEDs because that wavelength is not absorbed!
Each and every led needs to be atleast 1watt each. Anything below that will be useless so don't use old leds out of toys or old boards, they simply will have too little Total lumens versus lumens per watt. You need atleast 10mm LEDs with 1watt per LED to supply enough light to the plant anything lower will not work. A good combination is a pannel made from 75% 1watt red high brightness leds, 20% 1watt blue high brightness leds and 5% 1watt amber high brightness leds. somewhere in the region of 660nm for red and 460nm for blue
There is also no effective difference in penetrative power for horticultural purposes between a 1W LED and a 3W LED. So anything over 1watt is just wasted. This means brightness has very little to do with the benefit you will get once you use 1wat leds. Don't confuse this with a pannel made from say 20 LEDs rated a 10watt as to one with 10 LEDs rated at 10watt. As the 20 watt pannel will use the useless 0.5watt leds verses the 10watt pannel that uses 10x10watt 1watt LEDs that are ideal. This has been tested and proven that 1watt single LEDs have great benefit to plants and anything less is just a waste of time and has no benefit at all to plants. The same applies with going brighter than 1watt has no benefit either.
Hope that may help some of you. Especially if you are growing indoors.
Also LEDs are more efficient than any other form of grow lighting available.
The commercially available LED growlights outperform all other growlamps from HID lamps to including high pressure sodium (HPS) and metal halide (MH) lamps.
So prepare to see other grow lamps become obsolete as LED growlight take over.
or isit just to regulate
and my made grew plants useing blue (metal halide)
i got very fat leaves
he got more growth but very spindly leaves
so nxt time il do blue for growth and red for flowering
or just use white
you can use coloured plastic but it absorbs to much light for what its worth
low cost energy efficient bulbs you can get flood light versions but they cost about x10 more then the standard just use 3 or 4 of thr cheep 1`s
aparently you need 10 x 11 watt for good growth i think it depends on the size of grow area
Then it would be a renewable energy - LED Grow Light using Joule Thief Battery Power in a Wick Gardening Container for CHEAP!
If you can make it into perpetual energy machine you'll really have something ;-)
Thanks for clearing that up with the blue for growing and red for flowering.
Also, I know Wikipedia is not a truly scientific source, but I'm lazy and it's a quick find for things. In the end, if someone completely disregarded the wavelengths I placed on here and just bought "red" and "blue" LEDs they would still probably be quite successful with this project. On a side note, here is a link from the University of Hamburg (Germany) that verifies the wavelengths that I wrote earlier.
http://www.biologie.uni-hamburg.de/b-online/e24/3.htm
