3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Guess-O-Matic
LED Guess-O-Matic
How to create the fischertechnik LED GUESS-O-MATIC GAME:
I play with different educational manipulatives for a living. (Visit www.weirdrichard.com).
An easy-to-build application is the LED GUESS-O-MATIC GAME. The robotic controller (in this case the PCS BRAIN) randomly selects one of two LED to light. The LEDs are hidden behind mounting plates. Next to each LED is a push button. Guess which LED is lit by pressing one of the switches. If your guess is correct, the controller plays a happy tune! Guess incorrectly, and you receive a single beep.
This instructable will describe how to create a fischertechnik LED GUESS-O-MATIC GAME!
Note: The images were generated by a CAD program and a fischertechnik elements library.
Step 1Gather Elements:
Gather Elements:
You will need to gather your elements. The fischertechnik elements are available from a range of kits available from ebay, Craig's List, or fischertechnik retailers.
Elements can be purchased individually from www.fischertechnik.com.
The PCS BRAIN kit and electronic components can be purchased here:
http://edventures.com/imssc/nsimssc/index.php?&pid=12182
The PCS BRAIN kit and electronic components can be purchased in Germany here:
http://www.nwt-online.de/products_new.php?osCsid=16227515cbca6245b6280bbfacf08079
OR the controller and components can be replaced with similar items purchased elsewhere.
The Parts List:
2 Hinged Block Tab (#31426)
2 Hinged Block Claw (#31436)
4 Building Block 15 with Counterbore (#32321)
8 Building Block 30 (#32879)
2 Building Block 15 (#32881)
2 Building Block 15 with 2 Pins (#32882)
1 Base Plate 120x60 (#35129)
6 Mounting Plate 15x45 (#38242)
1 PCS BRAIN
4 Sensor Cables
Power Supply
2 LED Elements
4 Nuts
4 Bolts
4 Sensor Cables
2 Switch Elements
(A small screwdriver is useful to attach LED and TOUCH SENSORS to the Building Block 15s with Counterbores)
1 comment
May 21, 2009. 8:26 PMBerserk87 says:
what? you took pictures of a commercial product, and submitted it into a contest...(???)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:ftking_83702
