LED Halloween Face
1,026
7
Published
Introduction: LED Halloween Face
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
Halloween is just around the corner, why not make a fun led face to spook your visitors! This is a simple project that looks really cool at night. So lets get started!
Step 1: Gather Your Parts
1) 7 Segment, 8 Digit, SPI Display (http://www.gearbest.com/development-boards/pp_1437...)
2) 3x Arduino UNO (http://www.gearbest.com/boards-shields/pp_278170.h...)
3) Male to Male Wires (http://www.gearbest.com/other-accessories/pp_27815...)
4) Male to Female Wires (http://www.gearbest.com/diy-parts-components/pp_23...)
5) 2x 8x8 dot matrix (http://www.ebay.com/itm/like/221769629857?lpid=82&...)
6) Cardboard
7) Hot Glue
8) 9v Power Supply (optional but suggested)
Step 2: Connect Everything
There are a lot of wires in this project so make sure everything is correct.
View the first image, this will explain how to wire everything. I didn't include the SPI 7-segment display but all you need to do is this: [Pin 12 to Data In, 11 to Clk, and 10 to LOAD, VCC to 5v, and GND to GND].
On the dot matrix use male to female pins and hot glue them into place, then wire tie all the wires together to insure a good connection.
Step 3: Cut the Cardboard
Trace the displays and cut them out, simple.
Step 4: Glue the Displays Into Place
This is simple as well just put the display in the hole and hot glue around it. Also on the back side glue your Arduino's to the board.
Step 5: Program the Arduino's
Here's how it works, the main controller controls the mouth as well as the two eye's Arduino's. Each eye has its own Arduino to control the 8x8 dot matrix and everything is controlled by an 9600 buad serial connection.
You either can download the code or copy it from below.
The left eyes code is:
//code made by funguypro
int eye = 0;
// 2-dimensional array of row pin numbers: const int row[8] = { 2, 7, 19, 5, 13, 18, 12, 16 };
// 2-dimensional array of column pin numbers: const int col[8] = { 6, 11, 10, 3, 17, 4, 8, 9 };
// 2-dimensional array of pixels: int pixels[8][8];
// cursor position: int x = 5; int y = 5;
void setup() { Serial.begin(9600); // initialize the I/O pins as outputs // iterate over the pins: for (int thisPin = 0; thisPin < 8; thisPin++) { // initialize the output pins: pinMode(col[thisPin], OUTPUT); pinMode(row[thisPin], OUTPUT); // take the col pins (i.e. the cathodes) high to ensure that // the LEDS are off: digitalWrite(col[thisPin], HIGH); }
// initialize the pixel matrix: for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } }
void loop() { if(Serial.available() > 0){ char c = Serial.read(); Serial.write(c); if(c == 'a'){ eye = 1; } if(c == 'b'){ eye = 2; } if(c == 'c'){ eye = 3; } if(c == 'd'){ eye = 4; } if(c == 'e'){ eye = 5; } if(c == 'f'){ eye = 6; } if(c == 'g'){ eye = 7; } if(c == 'h'){ eye = 8; } if(c == 'i'){ eye = 9; } if(c == 'j'){ eye = 10; } if(c == 'k'){ eye = 11; } if(c == 'l'){ eye = 12; } if(c == 'm'){ eye = 13; } if(c == 'n'){ eye = 14; } if(c == 'o'){ eye = 15; } if(c == 'p'){ eye = 16; } if(c == 'q'){ eye = 17; } if(c == 'r'){ eye = 18; } if(c == 's'){ eye = 19; } if(c == 't'){ eye = 20; } if(c == 'z'){ eye = 25; } } if(eye == 1){ eye1_a(); } if(eye == 2){ eye1_b(); } if(eye == 3){ eye1_c(); } if(eye == 4){ eye1_d(); } if(eye == 5){ eye1_e(); } if(eye == 6){ eye1_f(); } if(eye == 7){ eye2_a(); } if(eye == 8){ eye3_a(); } if(eye == 9){ eye3_b(); } if(eye == 10){ eye4_a(); } if(eye == 11){ eye4_b(); } if(eye == 12){ eye4_c(); } if(eye == 13){ eye4_d(); } if(eye == 14){ eye4_e(); } if(eye == 15){ eye4_f(); } if(eye == 16){ eye4_g(); } if(eye == 17){ eye4_h(); } if(eye == 18){ eye4_i(); } if(eye == 19){ eye4_j(); } if(eye == 20){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } } if(eye == 25){ blink1_a(); } refreshScreen(); }
void eye1_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[1][1] = LOW; pixels[1][2] = LOW; pixels[1][3] = LOW; pixels[1][4] = LOW; pixels[1][5] = LOW; pixels[1][6] = LOW;
pixels[2][0] = LOW; pixels[2][1] = LOW; pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][7] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; pixels[5][1] = LOW; pixels[5][2] = LOW; pixels[5][3] = LOW; pixels[5][4] = LOW; pixels[5][5] = LOW; pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[6][1] = LOW; pixels[6][2] = LOW; pixels[6][3] = LOW; pixels[6][4] = LOW; pixels[6][5] = LOW; pixels[6][6] = LOW;
pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; } void eye1_b(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[2][0] = LOW; pixels[2][1] = LOW; pixels[2][2] = LOW; pixels[2][5] = LOW; pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; } void eye1_c(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[1][1] = LOW; pixels[1][2] = LOW; pixels[1][3] = LOW; pixels[1][4] = LOW; pixels[1][5] = LOW; pixels[1][6] = LOW; //1 pixels[2][0] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][5] = LOW; pixels[2][6] = LOW; pixels[2][7] = LOW; //2 pixels[3][0] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; } void eye1_d(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[2][0] = LOW; pixels[2][1] = LOW; pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][5] = LOW; pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; //pixels[4][1] = LOW; //pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; //pixels[5][1] = LOW; //pixels[5][2] = LOW; pixels[5][3] = LOW; pixels[5][4] = LOW; pixels[5][5] = LOW; pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; } void eye1_e(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; //pixels[4][3] = LOW; //pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; pixels[5][1] = LOW; pixels[5][2] = LOW; //pixels[5][3] = LOW; //pixels[5][4] = LOW; pixels[5][5] = LOW; pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; } void eye1_f(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW; pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; //pixels[4][5] = LOW; //pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; pixels[5][1] = LOW; pixels[5][2] = LOW; pixels[5][3] = LOW; pixels[5][4] = LOW; //pixels[5][5] = LOW; //pixels[5][6] = LOW; pixels[5][7] = LOW;
void eye2_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW;
pixels[1][3] = LOW; pixels[1][7] = LOW; pixels[2][2] = LOW; pixels[2][7] = LOW;
pixels[3][1] = LOW; pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][7] = LOW;
pixels[4][0] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; pixels[5][7] = LOW;
pixels[6][1] = LOW; pixels[6][6] = LOW;
void eye3_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][5] = LOW;
pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][1] = LOW; pixels[5][2] = LOW; pixels[5][5] = LOW; pixels[5][6] = LOW;
pixels[6][2] = LOW; pixels[6][3] = LOW; pixels[6][4] = LOW; pixels[6][5] = LOW; } void eye3_b(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][5] = LOW;
pixels[3][1] = LOW; pixels[3][2] = LOW; //pixels[3][3] = LOW; //pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW;
void eye4_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[2][1] = LOW; pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; pixels[2][5] = LOW; pixels[2][6] = LOW; //pixels[2][7] = LOW;
pixels[3][1] = LOW; pixels[3][6] = LOW;
pixels[4][1] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][6] = LOW;
pixels[5][1] = LOW; pixels[5][3] = LOW; pixels[5][4] = LOW; pixels[5][6] = LOW;
pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; } void eye4_b(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[1][0] = LOW; //pixels[1][1] = LOW; //pixels[1][2] = LOW; pixels[1][3] = LOW; pixels[1][4] = LOW; //pixels[1][5] = LOW; // pixels[1][6] = LOW; pixels[1][7] = LOW;
pixels[2][0] = LOW; //pixels[2][1] = LOW; //pixels[2][2] = LOW; pixels[2][3] = LOW; pixels[2][4] = LOW; //pixels[2][5] = LOW; //pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[3][0] = LOW; //pixels[3][1] = LOW; //pixels[3][2] = LOW; //pixels[3][3] = LOW; //pixels[3][4] = LOW; //pixels[3][5] = LOW; //pixels[3][6] = LOW; pixels[3][7] = LOW;
pixels[4][0] = LOW; //pixels[4][1] = LOW; //pixels[4][2] = LOW; //pixels[4][3] = LOW; //pixels[4][4] = LOW; //pixels[4][5] = LOW; //pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[5][0] = LOW; // pixels[5][1] = LOW; // pixels[5][2] = LOW; // pixels[5][3] = LOW; // pixels[5][4] = LOW; // pixels[5][5] = LOW; // pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[6][0] = LOW; // pixels[6][1] = LOW; // pixels[6][2] = LOW; // pixels[6][3] = LOW; // pixels[6][4] = LOW; // pixels[6][5] = LOW; // pixels[6][6] = LOW; pixels[6][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_c(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[1][0] = LOW; pixels[1][1] = LOW; pixels[1][2] = LOW; //pixels[1][3] = LOW; //pixels[1][4] = LOW; //pixels[1][5] = LOW; //pixels[1][6] = LOW; pixels[1][7] = LOW;
pixels[2][0] = LOW; pixels[2][1] = LOW; pixels[2][2] = LOW; //pixels[2][3] = LOW; //pixels[2][4] = LOW; //pixels[2][5] = LOW; //pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_d(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[1][0] = LOW; //pixels[1][1] = LOW; //pixels[1][2] = LOW; //pixels[1][3] = LOW; //pixels[1][4] = LOW; pixels[1][5] = LOW; pixels[1][6] = LOW; pixels[1][7] = LOW;
pixels[2][0] = LOW; //pixels[2][1] = LOW; //pixels[2][2] = LOW; //pixels[2][3] = LOW; //pixels[2][4] = LOW; pixels[2][5] = LOW; pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_e(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[1][0] = LOW; //pixels[1][1] = LOW; //pixels[1][2] = LOW; //pixels[1][3] = LOW; //pixels[1][4] = LOW; //pixels[1][5] = LOW; //pixels[1][6] = LOW; pixels[1][7] = LOW;
pixels[2][0] = LOW; //pixels[2][1] = LOW; //pixels[2][2] = LOW; //pixels[2][3] = LOW; //pixels[2][4] = LOW; //pixels[2][5] = LOW; //pixels[2][6] = LOW; pixels[2][7] = LOW;
pixels[3][0] = LOW; pixels[3][1] = LOW; pixels[3][2] = LOW; //pixels[3][3] = LOW; //pixels[3][4] = LOW; //pixels[3][5] = LOW; //pixels[3][6] = LOW; pixels[3][7] = LOW;
pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; //pixels[4][3] = LOW; //pixels[4][4] = LOW; //pixels[4][5] = LOW; //pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_f(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[3][0] = LOW; // pixels[3][1] = LOW; //pixels[3][2] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; //pixels[3][5] = LOW; //pixels[3][6] = LOW; pixels[3][7] = LOW;
pixels[4][0] = LOW; //pixels[4][1] = LOW; //pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; //pixels[4][5] = LOW; //pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_g(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[3][0] = LOW; //pixels[3][1] = LOW; //pixels[3][2] = LOW; //pixels[3][3] = LOW; //pixels[3][4] = LOW; pixels[3][5] = LOW; pixels[3][6] = LOW; pixels[3][7] = LOW;
pixels[4][0] = LOW; //pixels[4][1] = LOW; //pixels[4][2] = LOW; //pixels[4][3] = LOW; //pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_h(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[5][0] = LOW; pixels[5][1] = LOW; pixels[5][2] = LOW; // pixels[5][3] = LOW; // pixels[5][4] = LOW; // pixels[5][5] = LOW; // pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[6][0] = LOW; pixels[6][1] = LOW; pixels[6][2] = LOW; // pixels[6][3] = LOW; // pixels[6][4] = LOW; // pixels[6][5] = LOW; // pixels[6][6] = LOW; pixels[6][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_i(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[5][0] = LOW; //pixels[5][1] = LOW; //pixels[5][2] = LOW; pixels[5][3] = LOW; pixels[5][4] = LOW; // pixels[5][5] = LOW; // pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[6][0] = LOW; //pixels[6][1] = LOW; //pixels[6][2] = LOW; pixels[6][3] = LOW; pixels[6][4] = LOW; // pixels[6][5] = LOW; // pixels[6][6] = LOW; pixels[6][7] = LOW;
pixels[7][0] = LOW; pixels[7][1] = LOW; pixels[7][2] = LOW; pixels[7][3] = LOW; pixels[7][4] = LOW; pixels[7][5] = LOW; pixels[7][6] = LOW; pixels[7][7] = LOW; } void eye4_j(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][0] = LOW; pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW; pixels[0][4] = LOW; pixels[0][5] = LOW; pixels[0][6] = LOW; pixels[0][7] = LOW;
pixels[5][0] = LOW; //pixels[5][1] = LOW; //pixels[5][2] = LOW; //pixels[5][3] = LOW; //pixels[5][4] = LOW; pixels[5][5] = LOW; pixels[5][6] = LOW; pixels[5][7] = LOW;
pixels[6][0] = LOW; //pixels[6][1] = LOW; //pixels[6][2] = LOW; // pixels[6][3] = LOW; //pixels[6][4] = LOW; pixels[6][5] = LOW; pixels[6][6] = LOW; pixels[6][7] = LOW;
void blink1_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[4][0] = LOW; pixels[4][1] = LOW; pixels[4][2] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][5] = LOW; pixels[4][6] = LOW; pixels[4][7] = LOW; }
void refreshScreen() { // iterate over the rows (anodes): for (int thisRow = 0; thisRow < 8; thisRow++) { // take the row pin (anode) high: digitalWrite(row[thisRow], HIGH); // iterate over the cols (cathodes): for (int thisCol = 0; thisCol < 8; thisCol++) { // get the state of the current pixel; int thisPixel = pixels[thisRow][thisCol]; // when the row is HIGH and the col is LOW, // the LED where they meet turns on: digitalWrite(col[thisCol], thisPixel); // turn the pixel off: if (thisPixel == LOW) { digitalWrite(col[thisCol], HIGH); } } // take the row pin low to turn off the whole row: digitalWrite(row[thisRow], LOW); } }
The right eyes code is:
int eye = 0;
void loop() { if(Serial.available() > 0){ char c = Serial.read(); Serial.write(c); if(c == 'a'){ eye = 1; } if(c == 'b'){ eye = 2; } if(c == 'c'){ eye = 3; } if(c == 'd'){ eye = 4; } if(c == 'e'){ eye = 5; } if(c == 'f'){ eye = 6; } if(c == 'g'){ eye = 7; } if(c == 'h'){ eye = 8; } if(c == 'i'){ eye = 9; } if(c == 'j'){ eye = 10; } if(c == 'k'){ eye = 11; } if(c == 'l'){ eye = 12; } if(c == 'm'){ eye = 13; } if(c == 'n'){ eye = 14; } if(c == 'o'){ eye = 15; } if(c == 'p'){ eye = 16; } if(c == 'q'){ eye = 17; } if(c == 'r'){ eye = 18; } if(c == 's'){ eye = 19; } if(c == 't'){ eye = 20; } if(c == 'z'){ eye = 25; } } if(eye == 1){ eye1_a(); } if(eye == 2){ eye1_b(); } if(eye == 3){ eye1_c(); } if(eye == 4){ eye1_d(); } if(eye == 5){ eye1_e(); } if(eye == 6){ eye1_f(); } if(eye == 7){ eye2_a(); } if(eye == 8){ eye3_a(); } if(eye == 9){ eye3_b(); } if(eye == 10){ eye4_a(); } if(eye == 11){ eye4_b(); } if(eye == 12){ eye4_c(); } if(eye == 13){ eye4_d(); } if(eye == 14){ eye4_e(); } if(eye == 15){ eye4_f(); } if(eye == 16){ eye4_g(); } if(eye == 17){ eye4_h(); } if(eye == 18){ eye4_i(); } if(eye == 19){ eye4_j(); } if(eye == 25){ blink1_a(); } refreshScreen(); }
void eye2_a(){ for (int x = 0; x < 8; x++) { for (int y = 0; y < 8; y++) { pixels[x][y] = HIGH; } } pixels[0][1] = LOW; pixels[0][2] = LOW; pixels[0][3] = LOW;
pixels[1][0] = LOW; pixels[1][4] = LOW;
pixels[2][0] = LOW; pixels[2][5] = LOW;
pixels[3][0] = LOW; pixels[3][3] = LOW; pixels[3][4] = LOW; pixels[3][6] = LOW;
pixels[4][0] = LOW; pixels[4][3] = LOW; pixels[4][4] = LOW; pixels[4][7] = LOW;
The main/mouth controller is:
#include "LedControl.h"
LedControl lc=LedControl(12,11,10,1);
lc.shutdown(0,false); /* Set the brightness to a medium values */ lc.setIntensity(0,14); /* and clear the display */ lc.clearDisplay(0); Serial.write('t'); }
void loop() { Serial.write('g'); for(int i = 0; i<15; i++){ talk(100); } Serial.write('z'); delay(100); fangs(); for(int i=0; i<6; i++){ Serial.write('f'); delay(500); Serial.write('e'); delay(500); Serial.write('d'); delay(500); Serial.write('e'); delay(500); Serial.write('z'); delay(100); } for(int i=0; i<5; i++){ Serial.write('l');//l wistle(); Serial.write('k');//k wistle(); Serial.write('p');//m wistle(); Serial.write('s');//n wistle(); Serial.write('r');//o wistle(); Serial.write('z'); delay(100); Serial.write('q');//p wistle(); Serial.write('n');//q wistle(); } }
void mouth_close(){ lc.setLed(0, 0, 1, true); lc.setLed(0, 0, 2, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 1, 1, true); lc.setLed(0, 1, 4, true);
lc.setLed(0, 2, 1, true); lc.setLed(0, 2, 4, true); lc.setLed(0, 3, 1, true); lc.setLed(0, 3, 4, true);
lc.setLed(0, 4, 1, true); lc.setLed(0, 4, 4, true);
lc.setLed(0, 5, 1, true); lc.setLed(0, 5, 4, true);
lc.setLed(0, 6, 1, true); lc.setLed(0, 6, 4, true);
lc.setLed(0, 7, 1, true); lc.setLed(0, 7, 6, true); lc.setLed(0, 7, 5, true); lc.setLed(0, 7, 4, true); delay(250); lc.clearDisplay(0); lc.setLed(0, 0, 7, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 1, 7, true); lc.setLed(0, 1, 4, true);
lc.setLed(0, 2, 7, true); lc.setLed(0, 2, 4, true);
lc.setLed(0, 3, 7, true); lc.setLed(0, 3, 4, true);
lc.setLed(0, 4, 7, true); lc.setLed(0, 4, 4, true);
lc.setLed(0, 5, 7, true); lc.setLed(0, 5, 4, true);
lc.setLed(0, 6, 7, true); lc.setLed(0, 6, 4, true);
lc.setLed(0, 7, 7, true); lc.setLed(0, 7, 4, true); lc.setLed(0, 7, 5, true); delay(250); lc.clearDisplay(0); lc.setLed(0, 0, 4, true); lc.setLed(0, 1, 4, true); lc.setLed(0, 2, 4, true); lc.setLed(0, 3, 4, true); lc.setLed(0, 4, 4, true); lc.setLed(0, 5, 4, true); lc.setLed(0, 6, 4, true); lc.setLed(0, 7, 4, true); delay(250); lc.clearDisplay(0); }
void talk(int speed){ lc.clearDisplay(0); lc.setLed(0, 0, 1, true); lc.setLed(0, 0, 2, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 7, 1, true); lc.setLed(0, 7, 6, true); lc.setLed(0, 7, 5, true); lc.setLed(0, 7, 4, true); delay(speed); lc.clearDisplay(0); lc.setLed(0, 0, 7, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 7, 7, true); lc.setLed(0, 7, 4, true); lc.setLed(0, 7, 5, true); delay(speed); lc.clearDisplay(0); lc.setLed(0, 0, 4, true); lc.setLed(0, 1, 4, true); lc.setLed(0, 2, 4, true); lc.setLed(0, 3, 4, true); lc.setLed(0, 4, 4, true); lc.setLed(0, 5, 4, true); lc.setLed(0, 6, 4, true); lc.setLed(0, 7, 4, true); delay(speed); lc.clearDisplay(0); lc.setLed(0, 0, 7, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 7, 7, true); lc.setLed(0, 7, 4, true); lc.setLed(0, 7, 5, true); delay(speed); lc.clearDisplay(0); lc.setLed(0, 0, 1, true); lc.setLed(0, 0, 2, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 0, 4, true);
lc.setLed(0, 7, 1, true); lc.setLed(0, 7, 6, true); lc.setLed(0, 7, 5, true); lc.setLed(0, 7, 4, true); delay(speed); }
void fangs(){ lc.clearDisplay(0); lc.setLed(0, 0, 1, true); lc.setLed(0, 0, 2, true); lc.setLed(0, 0, 3, true); lc.setLed(0, 1, 1, true); lc.setLed(0, 2, 1, true); lc.setLed(0, 3, 1, true); lc.setLed(0, 4, 1, true); lc.setLed(0, 5, 1, true); lc.setLed(0, 6, 1, true); lc.setLed(0, 7, 1, true); lc.setLed(0, 7, 6, true); lc.setLed(0, 7, 5, true); }
void wistle(){ lc.clearDisplay(0); lc.setLed(0, 3, 1, true); lc.setLed(0, 3, 2, true); lc.setLed(0, 3, 3, true); lc.setLed(0, 3, 4, true); lc.setLed(0, 4, 1, true); lc.setLed(0, 4, 6, true); lc.setLed(0, 4, 5, true); lc.setLed(0, 4, 4, true); delay(250); lc.clearDisplay(0); lc.setLed(0, 4, 1, true); lc.setLed(0, 4, 2, true); lc.setLed(0, 4, 7, true); lc.setLed(0, 4, 6, true); delay(250); }
Step 6: Done!
Plug it in and watch it go!
Step 7: Did You Like This Project?
I work really hard on my projects to make sure everyone can clearly understand them. If you have any questions please leave them in the comments and i will try to answer them. Also it would be great if you vote for me in the circuits contest. Thanks everyone!!
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    2 Comments
    very cool, you could try adding an ultrasonic sensor and a buzzer so if a trick or treater walks by then the face will scream. Great project, I voted
    Thanks, the ultrasonic sensor is a good idea as well
