Step 7Program the Microcontroller
Load the program attached to this step (or in the intro) onto the microcontroller (the .hex file in the applet folder can be loaded onto the microcontroller in place of the bootloader). When burning the bootloader, set the chip to use the 8MHz internal crystal, unless you want to use an external crystal (the extra speed isn't really needed). If you do re-compile the code be sure it is at the correct clock speed for what you will be using.
Once it's programmed, put the chip into the socket on the breadboard.
LED_Diaplay_Code.zip91 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
