LED Heart Photo Frame - Make a Perfect Valentine's or Birthday Present
Published
Introduction: LED Heart Photo Frame - Make a Perfect Valentine's or Birthday Present
About: Founder and Author of www.HowToMechatronics.com, an education website in the area of Mechanical, Electrical and Computer Engineering. Tutorials, Tips, Tricks, How It Works, Projects, Examples, Source Codes, ...
Hello! In this instructable I will show you how you can make this awesome LED Heart Photo Frame. For all Electronics Enthusiasts! Make the perfect Valentine's, Birthday or Anniversary present for your loved ones!
You can watch the Demo Video of this project on the video below and read the step by step instructions how to build one in the text below. Also if you want you can watch a detailed DIY Video of this Project on my official website, www.HowToMechatronics.com.
Step 1: Demo Video
So what we have here is a simple photo frame with 32 LEDs in a shape of a heart on the back side of the photo. This is a really interesting DIY Projects and I recommend to all electronics enthusiasts to build one for their loved ones as a Valentine's or Birthday present.
Step 2: Components Requirements
Arduino Nano – via Banggood
Ultra Bright Red LEDs – via Banggood
Switch – via Banggood
Power Jack – via Banggood
DC 5V >1A Adapter – via Banggood
2 x TLC5940 LED Drivers
2 x 2K Resistors
1uF & 0.1uF Capacitors
Step 3: Get Ready the Photo Frame
First you need a simple photo frame with the following dimensions: 18 x 13 cm. Additionally you need a fiberboard cut to the size of the frame on which using a drill you will make 32 holes so that you can insert the LEDs in there.
The Anodes of all LEDs have to be soldered together and the Cathodes have to be connected to the TLC5940 PWM Driver. After soldering you should check whether all of the LEDs work properly.
Step 4: Wiring
Here's how the circuit schematics of this projects looks like. So using the Arduino Nano and the TLC5940 ICs you can control all 32 LEDs. You need few additional components, two capacitors for decoupling and two resistors for current limiting of the TLC5940. You can find more details how to connect and use this IC with the Arduino on my particular Arduino and TLC5940 Tutorial.
Step 5: Put All Together
Now according to the circuit schematics you need to connect everything together. First you should insert and solder all IC sockets and pin headers as well as the capacitors. Then you need to insert the Arduino and the LED Drivers and connect everything else using jump wires.
When you are done with this, you should again check whether the LEDs work properly before continuing. You can do that by uploading the Arduino code below.
Step 6: Arduino Code
For this Project I used the TLC5940 Library made by Alex Leone. You need to make some modifications when using the library with two TLC5940 ICs. You need to modify the tlc_config.h file and change the value of the variable NUM_TLCS to value of 2.
Here's the complete Arduino code:
<br><p>/*  LED Heart Photo Frame - Arduino Project<br> *  Program made by Dejan Nedelkovski,
 *  www.HowToMechatronics.com
 *</p><p>* TLC5940 Library by Alex Leone, https://code.google.com/archive/p/tlc5940arduino/
 *  You need to modify tlc_config.h located in the TLC5940 library
 *  and change the value of the variable NUM_TLCS to the numbers of TLC5940 ICs connected
 */</p><p>#include "Tlc5940.h" </p><p>int stage = 0;
int randomNumber;
int count = 0;
int brightness = 3500;
int brightUp = 50;
int dir=1;</p><p>void setup() {
  Tlc.init();
}</p><p>void loop() {
  switch(stage) {
    //-----Stage 1
    case 0:
      randomNumber = (int)random(0,31);
      Tlc.set(randomNumber,4095);
      delay(1500);
      Tlc.update();
      if(count >= 8) {
        stage = 1;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 2
    case 1:
      delay(75);
      for(int i=31;i>=0;i--) {
        Tlc.set(i,4095);
        delay(100);
        Tlc.update();
      delay(500);
      Tlc.clear();
      Tlc.update();
      stage = 2;
      delay(500);
    break;
    //-----Stage 3
    case 2:
      for(int i=0;i<=31;i++) {
        Tlc.set(i,4095);
      Tlc.update();
      delay(500);
      Tlc.clear();
      Tlc.update();
      delay(350);
      if(count > 6) {
        stage = 3;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 4
    case 3:
      for (int i=0;i<=15;i++) {
        Tlc.set(i,4095);
        Tlc.set(31-i,4095);
        Tlc.update();
        delay(70);
      delay(50);
      for (int i=15;i>=0;i--) {
        Tlc.set(i,0);
        Tlc.set(31-i,0);
        Tlc.update();
        delay(70);
        Tlc.set(i,4095);
        Tlc.set(31-i,4095);
        Tlc.update();
        delay(70);
        Tlc.set(i,0);
        Tlc.set(31-i,0);
        Tlc.update();
        delay(70);
      delay(50);
      Tlc.clear();
      Tlc.update();
      delay(100);
      if(count > 1) {
        stage = 4;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 5
    case 4:
      for (int i=15;i>=count;i--) {
        Tlc.set(32-i,4095);
        Tlc.update();
        delay(5);
        Tlc.set(32-i-1,0);
        Tlc.update();
        delay(5);
        Tlc.set(i,4095);
        Tlc.update();
        delay(5);
        Tlc.set(i+1,0);
        Tlc.update();
        delay(50);
      if(count > 15) {
        Tlc.set(16,4095);
        Tlc.update();
        delay(2000);
        stage = 5;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 6
    case 5:
      for (int i=0;i<=31;i++) {
        Tlc.set(i,brightness);
        Tlc.update();
      Tlc.update();
      brightness = brightness + brightUp;
      if (brightness>=3500) {
        brightUp=-50;
        ++count;
      if (brightness<=150) {
        brightUp=50;
      if(count > 6) {
        stage = 6;
        count = 0;
        brightness = 3500;
        Tlc.clear();
        Tlc.update();
      delay(40);
    break;
    //-----Stage 7
    case 6:
      for (int i=0;i<=30;i+=2) {
        Tlc.set(i,4095);
        Tlc.set(i+1,0);
      Tlc.update();
      delay(500);
        Tlc.set(i,0);
        Tlc.set(i+1,4095);
      Tlc.update();
      delay(500);
      if(count > 20) {
        stage = 7;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 8
    case 7:
      for(int i=31;i>=16;i--) {
        Tlc.clear();
        Tlc.update();
        delay(2);
        Tlc.set(i,4095);
        Tlc.set(i+1,2000);
        Tlc.set(i+2,1000);
        Tlc.set(i+3,500);
        Tlc.set(i+4,300);
        Tlc.set(i+5,200);
        Tlc.set(i+6,100);
        Tlc.set(i+7,50);
        Tlc.set(i+8,0);</p><p>        Tlc.set(i-16,4095);
        Tlc.set(i-15,2000);
        Tlc.set(i-14,1000);
        Tlc.set(i-13,500);
        Tlc.set(i-12,300);
        Tlc.set(i-11,200);
        Tlc.set(i-10,100);
        Tlc.set(i+-9,50);
        Tlc.set(i-8,0);
        Tlc.update();
        delay(50);
      if(count > 8) {
        Tlc.set(i,4095);
        Tlc.update();
        delay(50);
        stage = 8;
        count = 0;
      else {
        ++count;
    break;
    //-----Stage 9
    case 8:
        Tlc.set(i+8,4095);
        Tlc.set(i+7,2000);
        Tlc.set(i+6,1000);
        Tlc.set(i+5,500);
        Tlc.set(i+4,300);
        Tlc.set(i+3,200);
        Tlc.set(i+2,100);
        Tlc.set(i+1,50);
        Tlc.set(i,0);
        Tlc.update();
        delay(50);
        Tlc.set(i,4095);
      Tlc.update();
      delay(10);
      if(count > 8) {
        delay(8000);
        Tlc.clear();
        Tlc.update();
        stage = 0;
        count = 0;
      else {
        ++count;
    break;
}</p>
Step 7: Cover Box for the Electronics
After you have checked that everything works well using the above code now you need to finish the project by making a cover box for the electronics. I did that using some more pieces of fiberboard and glued them together for forming a box. At the back side of the box you need to make two holes, one for a power jack and another for a switch.
At the end all you have to do is print your photo, add it to the frame, secure it and your are done!
I hope you will liked this project. If it's so, for more cool projects and tutorial, you can always check my official website, www.HowToMechatronics.com and follow me on Facebook.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    4 Comments
    Why is it everyone keeps wasting arduino on LEDs that just light up only, for goodness sake just Charlie pixel it with resistors and a battery pack, that's all you need, don't get me wrong I love your design but it's a waste of an arduino.
    Yes of course there are many different ways of building something like this, even simpler, just like you said. But the point is that I usually do Projects using Arduino, so I have came up with this design.
    ...which is awesome, by the way ! This is what the TLC's are for, imho.
    I have a question to you, gkelly2 (hope you're reading this).
    First, what is "Charliepixeling"? I can't find anything about it on the internet. Is it a form of Charlieplexing?
    Second, the author used 32 LED's in a heart shape and used 4 Pins of a uC. To charlieplex 32 LED's you would need at least 7 Pins. Wouldn't that be worse?
    Some answers would be awesome ! :)
