3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
L.E.D. Hula Hoop Replacing Broken Battery Holder
http://CreativeDesignNFab.com
This is a walkthrough detailing how to replace a broken battery holder for an L.E.D. Hula hoop..Pretty straight forward.
Suplies needed for this are..
-Needle nose plies
-Cutting pliers
-Wire stripper of some sort
-Electrical tape (if you choose not to reuse the prexisting tape)
-Solder gun and solder(not required but is the primo route to take)
Step 1Removing Pushbutton Connector
-First depress the metal pushbutton down as far as you can (will make it easier to remove)
-With the needle nose pliers, reach inside the tube and grab the lip of the pushbutton.
-Now SLOWY and gently pull the pushbutton connector out. Sometimes it helps to twist while pulling.
-Now can pull alittle slack from inside the tubing to make things easier.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:CDNF
