3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Infinity Mirror, 32 LEDs, Selectable Patterns, Quality Frame
Step 8Make Connections and Wire Up the Controller
 If a controller board is not being used.
- And Auto-Change LEDs are being used connect the Power Supples V+ to LED's Anodes and V- to the LED's Cathodes (each LED has its own resistor).
- Single Current Regulator such as a large wattage resistor, connect LED+ to V+ with a large wattage(3w+) resistor, connect all the LED Cathodes to GND/V-
This step requires the 8 Channel LED Driver to be assembled.
Take a look at the wiring diagram and start finding which wires go where. You may want to label them if need be.
The screw-down terminal's are extremely small. I had to use a flat head screw driver from an eyeglass repair kit.
All LED#1's go to Terminal 1 on the PCB
All LED#2 go to Terminal 2 on the PCB
And so on.
Screw them in tight and watch out for loose strands of wire that could cause a short.
There are 2 wires that are labled LED+ on the driver, each side should have one of those wires soldered to its V+ rail(LED Anodes)
- Mount the panel-mount DC Jack into the 9/16" hole drilled into the outer wall.
- Take the button mounted to the perf-board and with some glue (super, hot, epoxy) apply a drop to the perf-board and place into the prepared hole. Glue it in good.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
