3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Infinity Mirror, 32 LEDs, Selectable Patterns, Quality Frame
Step 9Finish Up
Finish Up
- Carefully place in the 1/8th regular mirror face down from the back, and it should fit perfectly above the 2-way.
- Tape it in with Aluminum Tape(supplied in the kit) or another tape that doesn't curl or stretch (electrical/duct won't work to well)
- Flip the the frame over and remove the masking.
- Finally time to connect the PSU to the DC Jack. It should turn on.
- Test the button make sure it works correctly to change the pattern.
- Once tested, hot glue the driver PCB to the wall.
- With the kit are a few different colors of vinyl dots to be put over the button. Choose one and apply to the center of the button. I am using black
*If the tunnel effect is curving to one direction. You'll have adjust the rear-mirror (regular), just remove it from the frame and raise the side that it is turning towards with some tape, layer it till its the tunnel effect goes straight back correctly.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
