This is my take on Elemental LED's Jellyfish Lamp. (See the link below)
http://www.instructables.com/id/Jellyfish-Lamp/
It measures 11cm across the dome and is about 20cm tall.
You will need:
-2LEDs
Electricalwire
-Batteries
Patience
-Glue Sticks and Hot Glue Gun
An Old Pen
-Fibrous strands of plastic (Fibre Optics)
-Soldering Iron and Soldering Wire
-Deodorant Can Top/Cap
-Electrical Tape
-Bubble Wrap
-Scissors
-Wire Cutters/Wire Strippers
-Clear tape
-A Clear Plastic 2L Soft Drink Bottle
Step 1: Make the Shell
For this step, cut the bottom of a 2 Litre bottle off and, using a soldering iron, create slits around the 5 protrusions as shown. DO NOT go all the way through the edge, but rather stop about 5mm above. This ring is important for the structure of the jellyfish. After you have done all 5, push them inwards until they look right. Glue in place with hot glue.
Optional: When done with this, sand the top of the dome with fine sandpaper as this will give it a blurry effect.
camtheman1283 says: Dec 17, 2012. 1:32 PM
That poor soldering iron :(
awesomecreations (author) in reply to camtheman1283Dec 18, 2012. 11:31 AM
It's fine, but it has gotten revenge on my fingers a few times already.
thatswhatshe says: Dec 17, 2012. 12:17 PM
nice
marcellahella says: Dec 17, 2012. 11:39 AM
cool!
awesomecreations (author) says: Dec 17, 2012. 1:33 AM
I used a black deodorant cap so it is less visible at night and makes the jellyfish appear to be floating
awesomecreations (author) says: Dec 16, 2012. 11:22 PM
A cool bonus is that if the wires are placed loosely against the batteries and speakers are on near it, the wires vibrate and the jellyfish lights up with the sound and flashes.
awesomecreations (author) says: Dec 16, 2012. 10:51 AM
I made it with 2 separate switches, so I can switch on the blue or red LED or I can switch both on.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
