Introduction: LED LAMPS OUT OF OLD LAMPS
After the LED build night we had many projects, we went about converting all old table lamps into LED ones. The LED ones were much more cooler than the bulb versions of it. The only additional thing that we had to add to it was a transformer and some diodes.
LED lamps consume lower power than the, desk lamp that it once was.
Step 1: Parts and Tools
Lets Start with finding an old table lamp we had 3 of it.
Components
- LEDS
- 1N4007 Diode x4
- 3v-0v-3v Transformer
Tools
- Screw Driver
- Pliers
Step 2: Finding a Proper Lamp
Finding a proper lamp is the first step we need to do the lamp we are Looking for is the old desk lamp with a switch with no circuit boards inside. Then start disassembling the lamp you will find the power wire connected to the terminal which holds the bulb in place.
Step 3: Adding the Transformer
Ok now is time to convert the 220V to 3v, get a 3v transformer from eBay or a local hardware store connect the Transformer to the power line which goes to the bulb I removed the bulb holder to make space for the LEDs.
Step 4: LEDs
Ok now it’s time to add the LEDS, The LEDs are in parallel with each other and then connected to the transformer. We soldered the LEDs on the PCB to get good support. Before closing it, power it once to see if the LEDs are lighting up.
Step 5: Enclosure
Enclose all of it in the enclosure and use tapes or Sugru to hold the LEDs in place. And now you have a Cool LED desk lamp.
