Remove these ads by
Signing UpStep 1MATERIALS/TOOLS
Aluminum sheet 12 to 20 mils thick.I used left over Al house siding.
Central rod. A skewer .075Dia.x15 in. long [Dollar store} Has a wooden handle for tail fin.]
Wire to mount device- Coat hanger wire .062Dia.x 10 in. long.
Propeller Hub. Block of Foam Polyurethane 1 in. thickness to cut out 2 in. round. Can use wood too.
LED- any color. I used red led 2v. 20ma. from Rad Shack. The longer lead is plus connected.
Screws/nuts- 6/32 x 1/2 in. long to adhere the motor.
Large rotator 4 in. diameter pop bottle. Smaller size can be a pill bottle 2 in. dia.
A bottle cap and an inner corked wine stopper.
Pulley- rubber band. I used a ladies hair rubber band.
Tube- mounting of prop on tube and slid onto above skewer.
TOOLS- E6000glue. as required to hold prop blades into the polyurethane Hub.
Epoxy paste- Spread over exposed Hub to seal from water=rain.
Scissors . pliers, screwdriver.small clamp to hold prop at front of axle skewer.
Soldering Iron 40W. and 60/40 solder. To connect motor to Led.
Paint or decals.
4
comments
Add Comment
mistic (author)
says:
mistic (author)
says:
mistic (author)
says:
Add Comment
