LED Lego Light Saber
12,336
87
11
Published
Introduction: LED Lego Light Saber
Parts and things needed:
1. Your favorite StarWars Lego figure and a light saber
2. A small LED bulb (try to find a color that matches the sabers)
3. A small button-battery pack
4. Thin gauge wire
5. Electric drill and your smallest drill bit (must be thinner than the saber handle)
6. Super Glue
7. Solder and solder gun (Optional, it can work just fine twisting the wires together at the stripped ends)
8. The Force
Step 1: Drill Tiny Hole Thru Saber Handle
This is a delicate drilling, but easily accomplished with a simple work table vice to hold it fast while you drill straight down the center.
Step 2: Light and Battery
Take a small LED light from any cheap toy. Take a tiny battery from some cheap toy, the smaller the better. This one fits nicely onto a Lego "backpack"
Step 3: Attach LED to Saber Handle Bottom
Super glue blue LED into bottom of saber handle. The hole you drilled is to simply let the light pass through to illuminate the "laser" part of the sword.
Step 4: Simple Wiring, Part 1
Wrap one end of the wire (+ or - end) around the wrist with exposed wire crossing front of the palm
Step 5: Simple Wiring, Part 2
Wrap the other end (just be sure it is the opposite charge) of the wire around the saber handle, with exposed wire running across the section that connects to the hand
Step 6: Attach the Battery Pack
Glue battery pack to a lego "back-pack", or simply directly onto characters back
Step 7: Off
Off-position
Step 8: On
On-position
Step 9: The Force
Your StarWars figure now has The Force, and may it be with you!
  • Water Contest
    Water Contest
  • Creative Misuse Contest
  • Clocks Contest
    Clocks Contest
11 Discussions
The backpack makes Luke Skywalker look like a ghost buster.
Good job though! Legos and LEDs are two of my favorite things!
Very nice! What kind/gauge of wire did you use? It looks like magnet wire but I can't tell. Have you thought about smaller LEDs like SMDs?
@ProfMuggs Im thinking 28 AWG wire, is be pretty close or exactly what he used, Your guess of magnet wire would work too. ;)
oh, there are lots of improvments that could be made, everyones ideas here are good. I am going to embed the battery in a hole I make in the body off the character itself. my wire spool is blank..but I think you are right, very thin.
w1ng0
3 years ago
Yes definitely try 0805 LED's with one 3v battery embedded I will try myself on the next project
Why not to install the led on the top and glue the blue saber onto the led ? the light would be much better...
I agree, it's an improvement you have to try. But you're idea is already really cool!
