3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Light Drawing Pens: Tools for drawing light doodles
Step 5Add the Power Source
Finally add the batteries. This is very low-tech, but I have yet to find or build a battery holder that suits my purpose.
Strip the ends of the wires and wrap the bare wire and a small bit of aluminum foil together into a ball.
(I call myself a photographer, but I obviously need to work on my depth-of-field and flash diffusion skills.)
Use the electrical tape to hold the batteries together in series (postive terminal to negative terminal) and the wire ends in place on each end of the battery stack.
Polarity is important here. Test the light at this point and try reversing the connections if it does not work. (Remember that you have to push the switch while testing.)
Wrap a second piece of tape around the terminal ends. Stretch and wrap the tape tightly, insuring a postive connection.
Fit the battery pack into the end of the finished pen.
4 comments
Feb 21, 2010. 3:21 PMmlavery85 says:
 The aluminum foil dose not stay on!!!  Why do we need it?
Mar 8, 2010. 1:20 PMabbeynormal42 says:
I left about an inch of wire exposed and wrapped a layer of foil around the lower 1/2" of it.   Then I folded the remainder of the exposed wire down over the foil and continued wrapping the foil around it.  It stays really well!!
Unrelated: I'm a teacher, and I did some light-drawing with my students for their classroom book.  Would it be okay if I included a picture of your light pen collection?  We have this explanation we wrote at the beginning of what light-drawing is, and your picture would help greatly!
Mar 7, 2009. 4:04 AMbugs_rus21 says:
thank 3 very much, it helps me gratly!
Feb 6, 2008. 1:33 AMAnkush says:
Amazing!!! beautifully illustrated.Keep up the gr8 work!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
64
Author:unklstuart
