LED Light Mashrooms
Published
Introduction: LED Light Mashrooms
This LED Light Mushroom is a really easy and fun project. I actually was inspired by a project called "LED light tubes" you an find it at https://www.instructables.com/id/LED-light-tubes/
Hope you like this project and have fun.
Step 1:
Take a Colgate tube, or any toothpaste would work if it has no color.
Step 2:
Take out some paste in a plate. The amount depends on how much color do you want to make.
Step 3:
Then take any sort of color it can be acrylic also but don't use watercolor the point is to use a thick color i used Poster color. i took Ultramarine (blue). take a small amount of it with a brush and put it on the paste put it on the side.(use more amount if you want to make it darker)
Step 4:
Use the back of the brush to mix until all the colors is evenly distributed.
Step 5:
Glitter Time
this part is optional but i used glitter(don't put all the colors at once it will become a total mess)(just look at the pictures)
Step 6:
Take a big size bottle an cut it with a cutter in the shape of a lamp.(or any shape would work)
Step 7:
Paint the inside of the mushroom not the top because when ever your gonna hold it all the color will be on your fingers. Don't make a thick layer we want to let the light out to give the effect.
Step 8:
After half an hour put an LED light turn it on at the night and put it on the garden grass if you want to make it permanent put in a real Bulb and glow whenever you want to.
The reason for me to use toothpaste and not actual paint was that a real paint will be thick won't give the effects but the toothpaste will be lighter and brighter.
you can also put the the toothpaste in a pattern but i went random.
    • Flowers Challenge
      Flowers Challenge
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    2 Comments
    I love the use of toothpaste! I never thought you could do anything like that. I'm sure it's nice and minty fresh for at least a couple days as well. :)
    thanks but it will dry after a few days
