Parts List:
Blind Replacement Wand - http://www.lowes.com/pd_3662-978-NW015239_0__?productId=3067205&Ntt=blind+wand&pl=1¤tURL=&facetInfo=
LEDs
Resistors - you can figure out the appropriate resistor here: http://ledz.com/?p=zz.led.resistor.calculator
Wire
Hot Glue
Heat Shrink
Power Source
Scrap wood
Cardboard
Metal Duct Tape
Tools needed:
Pencil (Naturally)
Jig Saw
Sander
Dremel
Dremel Cutoff Wheel
Dremel high speed cutter
Glue Gun
Oven
Basically, I made an LED wand,as seen in the photo below.
Remove these ads by
Signing UpStep 1: Find your design and make your pattern!
Once you come up with your design, make a pattern. You will need this to bed the wand around in the coming steps. I started by copying my design onto onion paper, and then onto cardboard. I then traced the card board onto 3/4 inch thick wood, which was probably overkill, but what I had on hand. Then, I cut the wood piece out using a scroll saw, and sanded it perfect. This will be the piece that you mold the wand around.
PKM says:
Aug 10, 2012. 3:49 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
