LED Lightbulb
LED Lightbulb
This was just a lark that had been itching in the back of my head for a while. It's a mains powered LED lightbulb.
Step 1Supplies
There's not too many things you need for this project.
An incandescent light bulb.
A .47 microfarad 200V capacitor.
1/4 watt 1kilo ohm resistor
a pair of leds
and miscellaneous things.
125 comments
1-40 of 125next »
Jan 3, 2012. 1:48 PMandr3w99 says:
I have a question... since i am young, i order from a VERY cheap website... they are the same quality items & i would like for you to help me...
i order from www.TaydaElectronics.com this website is EXTREMELY cheap, but sometimes it is hard to find what you are looking for. Can u help me find the 47 microfarad 200V Capacitor & the 1/4 watt 1kilo ohm Resistor... i dont want to order something, have it turn out its not the right type[s] and have it burn or shock me... thanks
Nov 7, 2011. 2:54 PMboyrock375 says:
by the way be careful cleaning out the bulb.....when breaking the glass base inside there is an inert gas in there so be sure your carefully and i suggest doing the initial breakage outside
Aug 8, 2011. 2:32 AM.Unknown. says:
How much current do you think this thing draws, roughly?
Jun 27, 2011. 8:34 PMqwerty156 says:
Hey!
I pulled out a capcitor from one of those cheap chinese flashlights that charge from ac
It looks a bit like this
http://www.surplus-electronics-sales.com/Zencart/images/products/120-1002%20p1%20radial%20mylar%20cap.gif
Do you think i should give it a try?
I live ina 230v area
Jun 28, 2011. 1:54 AMomnibot says:
Whoa! If you're not sure you shouldn't mess with high voltage! That stuff WILL hurt you. Go through the calculations and read up on the capacitor and safety. Then try it but NEVER mess with mains voltage if you feel uncertain about anything.
Jun 28, 2011. 3:16 AMqwerty156 says:
i saw your post just after i tried it lol!
Anyway, the resistor burn out but the leds are fine.
Protip - DO NOT TOUCH THE CAP! Nasty suprise!
Jun 28, 2011. 9:18 AMDaniel Deacon says:
electric shock?
Jun 28, 2011. 12:48 PMSowee says:
Probably it was damn hot and he burned his fingers.
Jun 28, 2011. 10:27 PMqwerty156 says:
nope, it was a shock. scared the crap out of me!
Feb 4, 2011. 2:34 PMwd0013 says:
To:Tool Using Animal
Awesome post. I especially like the usage of a filter cap in lieu of a (very unnecessary) bridged rectifier. I like bridged rectifiers in larger arrays, but simplicity is always more elegant. Keep 'em coming!
To: Everyone else
As an engineer that does waaaaaaay more dangerous experiments than this, let me tell you all that:
A: There's not enough current draw from that small apparatus to do anything really harmful to the cloths pin. During a malfunction, the cloths pin could get charred, but there would be absolutely NO fire.
B. At the end that is being held (the side with the LED - this side of the resistor and cap), there is only a miniscule amount of power. It takes high voltage to create any kind of arcing across the cloths pin (much less to the fingers pictured here). I'm talking 500+ volts. Voltage levels of 120 - 240 (depending on which country you're from) simply will not arc in such a fashion. Honestly, though you would feel it, there is (most likely) so little power (on the LED side) that you could comfortably touch the leads for a couple of seconds, as long as it was only one hand touching. Of course body chemistry, grounding, humidity, your own level of intelligence , and many other factors means that mileage will vary here. DON'T BE STUPID - MY RESPONSE IS SHOWING THEORY NOT PRACTICE!
The reality is that "real world" electronics testing in the A/C world is typically (at least) this dangerous. Common sense, knowledge, and study are your best friends in the lab (at home or work), so read a book folks!
ONLY THOSE THAT THINK FOR THEMSELVES SHOULD EVEN READ THIS RESPONSE - SHEEPLE GO ELSEWHERE!
Sep 6, 2009. 10:57 AMdany_mid says:
hi I live in Europe and here my socket electricity has 220V at 92 mA 50 hz please could you tell me what capacitor should i use?
Nov 2, 2010. 8:56 PMTheadamjacob says:
Your socket does not put exactly 92 mA. You have to measure it with a load. I think you can use 2 of these capacitors.
Nov 2, 2010. 8:54 PMTheadamjacob says:
A variable capacitor can give you adjustable voltage
Oct 31, 2010. 8:01 AMjules15 says:
How did you come up with the .47uf cap.. i want to know how to make other voltages like 6,9,12.. Is there a formula?
May 30, 2009. 11:29 PMmanuhui says:
Hi, if i want to put more than 2 LED, lets say 8 or 10, I put them in pairs, each pair opposite and with their resistor, in parallel or in series ? is that viable ?
Aug 27, 2010. 7:30 PMmegapix says:
You would put the pairs in series, and you would still only need one resistor and capacitor for the string. There are a couple of instructibles which do exactly that.
Jul 14, 2010. 3:39 AMnoingwhat says:
I have the same question, I have an idea for a simple 9 LED array that should make it so that it will work almost as well as a traditional bulb. I just don't exactly know the circuitry for it, and this ible was a good place to start. I still need to know if I should put them in series or parallel though.
Jul 16, 2010. 11:27 PMnoingwhat says:
Is it really necessary to wire two LEDs in opposition? Is the flicker noticable if you didn't?
Aug 27, 2010. 7:28 PMmegapix says:
Yes, its necessary, but not because of flicker. LED's have a "reverse breakdown voltage" of only about 5 volts, so a single LED would break down as soon as the line voltage reversed direction. Although the capacitor and resistor might prevent instantaneous destruction, the LED lifetime would likely be reduced. By putting a second LED across the first LED, with opposite polarity, the two LED's protect each other from high reverse voltage, and double the light output, and reduce flicker. What a deal!
Aug 14, 2010. 11:17 PMbrando112186 says:
(removed by author or community request)
Aug 14, 2010. 11:28 PMbrando112186 says:
Aug 15, 2010. 2:59 PMnoingwhat says:
Ah yes, I forgot about that. Thanks!
Jul 23, 2010. 2:12 PMKG4ZUZ says:
You DO NOT have to use a .47 uF mylar capacitor nor do you have to use a 1k ohm resistor, I have built 5 of these lights using a capacitor value ranging from .1uF to .68 uF all at 250 volts or more, I also have used a .uF capacitor with a 2.2k resistor and they all work great. You can use almost any value cap and resistor combination as long as the caps are at least 250 volts.You MUST use a MYLAR type of cap though
Jul 14, 2010. 3:35 AMnoingwhat says:
The wooden clothespin wouldn't conduct any electricity, but there is still the chance of, as he said, fire, or also a spark either from the LED to you, or from the LED to the clothespin spring to you.
Jul 8, 2010. 7:15 AMcicusninja says:
Is this circuit for 250VAC or 125VAC ? what do I have to use for 250VAC?
Jun 15, 2010. 5:45 AMw0rm5 says:
Despite of what my freind below says, I built it with a 0.47 capacitor, 1KOhm resistor, conected, lit it up ok, oh really good.......... NOT, after about 1 hour the resistor burned out, so in 127V, it overheats.
Jun 14, 2010. 3:07 PMw0rm5 says:
Hi, nice one, but what about the capacitor plarity, how do I hook it, negative side to led or the oether way? Thanks
May 23, 2009. 10:26 PMspyler03 says:
where can i buy the .47 microfarad 200V capacitor?
Jun 13, 2010. 8:06 PMkill-a-watt says:
search for orange drop capacitor
These are typically 600V, which is over spec, but OK (under spec would not be OK).
You could also take apart old power supplies, if you know what to look for and can do it safely.
Jul 26, 2009. 11:55 AMreasonforwarfare says:
Radioshack carries both capacitors and resistors. They also carry LEDs for around $2.49 for an ultra bright LED.
Jun 10, 2010. 5:48 PMjules15 says:
Thank you very much for posting this project. I just finished it and it works great.. Hope to save money : )
Apr 28, 2010. 11:49 PMDarksun010 says:
Went to Radio Shack and they didn't have a .47 microfarad cap 200 volts, but they had a .047 microfarad cap 630 volts.  Will that work???  It cost a $1.59.
Mar 16, 2010. 7:47 PMtaikombuter says:
I'm a new member ! So, i need you explain more to connect 2 led together.
You can post 1 picture of wiring diagram. Thanks !
Sep 3, 2009. 4:15 AMalzrc_13j says:
ei what if i use a polarized capacitor???would it make some difference???i cant buy a non polarized capacitor in our place hahahahaha....
Dec 28, 2009. 3:51 AMlilpepsikraker says:
Dec 27, 2009. 6:11 PMtjmortenson says:
Are they regular 3 volt or 120 volt leds?
1-40 of 125next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
248
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
