LED Matrix Cube
5,560
127
Posted
Introduction: LED Matrix Cube
Use WS2812 LED matrix and clear display boxes and Blinkytape controller to build a simple programable RGB LED matrix Cube in 30 minutes.
Step 1: Material
WS2812 8*8 matrix: 5 pcs or 6pcs
Blinkytape controller *1pcs ( Or you can get one Blinky Matrix from Blinkinlabs, which has already solder the blinkytape controller on the WS2812 matrix. Then you only need 1 BlinkyMatrix + 4~5 WS2812 8*8 matrix)
micro usb cable
DC jack
5V 8A max power supply
Blister display box: 8cm*8cm*8cm
blister display box: 9cm*9cm*9cm, if you don't have,can cut some PVC or PET(Polyethylene Terephthalate) to make one.
clear tape
Step 2: Software:
Step 3: Assemble
1.Drill holes on each surface of the 8*8*8 blister display box.
2. Attach the matrix to each side of the 8*8*8 blister display box, and put the jst cables into the display box
3. Connect the JST connectors from Matrix 1 to 2 to 3 to ... inside the display box.
4. Connect the first input just box to the Blinkytape controller
5. Solder the Diode 1N5817 to the power input of the matrix VCC, to make sure the power input should be correct.
6. solder the DC jack positve to the 1N5817 and DC jack ground to the matrix's ground.
Step 4: Upload the Software to the Blinkytape Controlller. Then It Looks Like This
  • Very similar to mine...-mic159
    mic159 made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
  • Sew Warm Contest 2018
