3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Mod Your Gameboy Color
Step 2Take it Apart
Take it Apart
Now you need to take apart your Gameboy. Flip it over on its front, so the back is facing up. Unscrew the six tri-wing screws. Two are at the top, two in the middle, and two at the bottom, under the batteries. Put these in a safe place.
Lift the bottom half of the case off the top one, then unscrew the three screws near the lower half of the PCB. Make sure you save these.
Once you have that done, you need to disconnect the screen. Lift both black plastic pegs toward the orange ribbon cable at the same time, then lift the cable from the connector.
1 comment
May 29, 2009. 8:17 PMbubba4561 says:
How do you use the flat head to unscrew the tri-winged screw? I've been trying all day and can't figure it out
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
266
Author:1up(ModRetro)
Sometimes my Instructables are few and far between, but I try to make them as well as I can. Hopefully you can be inspired or helped by the content in them!
