Step 3Cut the Switch Hole
Start by scoring the case of the Gameboy in the spot you want to put the switch. I found there is a lot of room just underneath the battery compartment. Cut the hole a little smaller than needed. You can always cut it bigger, but you can't cut it smaller. Keep cutting until you cut all the way through. It takes a long time, but it's worth it for a clean cut.
After you have the hole cut out and the switch fits, drill the holes for the screws. I like to put the switch in first, then drill through the hole for the screw.
Add Comment
