Step 5Buncha' Soldering
Take your switch and solder two wires to the switch. I didn't use red and black, but you can if you like. IMPORTANT: Put the switch in its hole before you solder the wires to anything, or you will have troubles later.
After you put the switch in, solder one of the wires to the negative battery terminal labeled BT- on top of the white part of the PCB. Next cut the leads shorter on your LEDs, then solder red and black wires to one of them. Solder the other ends of the wires to your other LED, making sure you pay attention to the polarity. You can tell on the LED which side is positive because the negative side has a flat spot at the base.
Solder the other wire from the switch to the negative side of one of your LEDs. You should have something like in the sixth picture.
Finally, solder a short wire from the positive side of your LED to the positive battery terminal, labeled BT+. My LEDs are rated for 3.1v, but if your LEDs are rated for a lower voltage, you may want to add a small resistor (100 Ohms) to extend the life of them.
You should now have everything soldered together! Flip the switch and see if everything lights up okay. If not, check all your connections, and make sure you have the polarity right on your LEDs.
You may want to insulate the connections to the LEDs, but I didn't find a problem with it.
Even though we specifically make a portable NES, I will cover briefly how to "portablize" other systems.
heres some pixs:
Front of GBP
http://i283.photobucket.com/albums/kk317/Chi-kitory/100_5036.jpg
Back of GBP
http://i283.photobucket.com/albums/kk317/Chi-kitory/100_5037.jpg
as close as i could to the power switch
http://i283.photobucket.com/albums/kk317/Chi-kitory/100_5039.jpg
another of the back
It's all my fault, too... :cry:
