Remove these ads by
Signing UpStep 1Gather Materials
Resistors that match your LEDs
Small Switch
Any transparent, colored Gameboy Advance
Small Wire
Tri-Wing Screwdriver OR small flathead screwdriver
Solder
Soldering Iron
Fine Sandpaper (400 - 500 grit)
Two LEDs (any color) (preferably low voltage)
Dremel/Rotary tool
Hot glue gun
Hot glue
Heat shrink tubing
Optional materials:
Helping hands
Xacto knife
Later, I tried shorting across the switch. GBA still works. Just have to take one of the batteries out. Not like that's a huge hassle, the battery doors ALWAYS break, right?
So I wired up 6 green LEDs. Wired up one backwards, but its not like that REALLY matters much lol its WAAAAY bright. Now I can't really see the screen so well. I didn't bother diffusing them either... I can always do that later.
I have 4 across the bottom (actually 3+1 that's soldered in backwards) then one to the right of the speaker, and one under the start+select text. Its freaking bright.
Yes, it would be possible to use some LEDs and a piece of acrylic as a backlight, but it would be a very tight fit. If you are planning on making a backlight, I would recommend using some low voltage LEDs, as the Gameboy uses a considerable amount of power for use. You should also look for thin acrylic, and place it in front of the LCD screen. Here is a link to an Instructable that shows you how to backlight an LCD.
http://www.pocketheaven.com/ph/boards/viewtopic.php?t=6813
This link shows you detailed pictures of where you can find a 5V power source on the PCB.
Good luck.
http://forums.benheck.com/viewtopic.php?f=22&t=41129&p=437777#p437777
there are some pictures of the final product.
I have pictures of the inside too, I didn't take enough to go step-by step, but if you want to see some, I will upload them.
