LED Motorcycle Headlight
In order to reduce the power consumption of the lighting system of my electric vehicle, I took it upon myself to change all of the lighting to LEDs. When it came to replacing the incandescent 18 watt 310 lumen headlight bulb, none of the drop-in LED replacement bulbs looked good to me.
Also none of them offered output levels that were comparable to or better than the bulb I was trying to replace.
So I shopped around and decided to make my own. The approach I took was probably more complicated than what most of you will actually need, but since I put both available options in one headlight I can explain how to implement both.
DISCLAIMER
LED headlights are not DOT approved, so use at your own risk. The one I made was installed on an electric moped.
This guide assumes you will be using an input voltage between 12 and 14 volts. If you are using a different input voltage or LEDs of different ratings than what is indicated in this write-up you should use an LED Calculator to determine what resistors you need to use.
I would recommend this LED Calculator
The cost of this project ranges from $15 to $65 depending on whether you are making a new headlight from scratch, or adapting an existing fixture to use LEDs. This is primarily meant to be an introduction and overview of the options available for making an LED-only headlight.
Step 1Part 1: LED Array Running Light
This option will be the most cost effective and easiest to assemble with basic tools. It's adaptable to whatever size, shape, or style of headlight you decide upon and if needed you can tailor the output level and pattern as well.
To calculate the potential output of the array you are going to make take the rating of the LEDs (6000mcd = 6 candela = 6 lumens) then multiply by the number of LEDs you intend to use.
I used 20 of the 6 lumen LEDs, so 20 x 6 means my output is approximately 120 lumens.
If you want more intensity it's best to start by using LEDs of a higher rating. Also keep in mind that even 6,000mcd LEDs will be painful to look at directly in the dark and will need to be diffused somewhat.
You can diffuse LEDs
1. by sanding their lenses with 600 grit sand paper
2. by making a soft diffusor sheet out of 1/16th or 1/8th inch clear or tinted acrylic or polycarbonate and then sanding it with 600 grit sand paper
3. by making a heavy diffusor plate out of 1/16th or 1/8th inch thickness white polyethylene sheet
Part 1 Supplies
1. Headlight fixture
2. Thin Polycarbonate or other suitable plastic sheet
3. Bulk lot of 50 to 100 white LEDs in 6000mcd or higher
You can order these cheaply from Chi-Wing LED Product Shop
4. Resistors (180ohm 1/4w for 13.4v max input or 220ohm 1/4w for 14v max input)
5. 22ga Wire
6. Pack of full sheet label paper
Part 1 Tools
1. 45w+ Soldering iron
2. Wire cutters
3. Power drill
4. Tin snips, band saw, or scroll saw (tool for cutting thin plastic)
5. Super glue
6. Hot Glue (optional)
7. Scissors
23 comments
Sep 16, 2011. 1:16 PMganpool says:
Good
Jan 3, 2009. 2:10 PMShaiGar says:
This Instructable is very interesting. I've got a SYM VS 125 scooter and I'm looking to make the headlights more powerful, with a better view of the road and surroundings (there are morons in Darwin, NT, Australia who like to walk on the roads wasted, or just throw their children onto the roads in front of government vehicles for compensation money) so I'm going to try this at home before attaching it.
Aug 15, 2011. 12:46 PMwobbler says:
The Royal Blue used to have some UV in them and they really did make road signs glow at a distance. Unfortunately, I think they might have taken the UV out of them now and blue in the UK is illegal on the road.
Apr 29, 2010. 8:45 PMnedlloydcaypuno says:
Sir,
Im Ned from Manila, just want to know if this would work on my scooter if my headlight is running on AC not DC?
Aug 15, 2011. 12:43 PMwobbler says:
You would need to rectify the AC to DC using a bridge rectifier (you could use four single diodes, but for the cost of a bridge rectifier, it's probably not worth it). Here's an example:
http://www.maplin.co.uk/bridge-rectifiers-19088
You would connect the alternator to the two AC symbols (doesn't matter which way round) then the rectifier would provide DC +/- on the other two terminals.
Then you can run your scooter and measure the DC voltage on the outputs and then calculate the number of diodes and resistor values as shown here by Captain Slug.
There is a rough idea of how to do it here:
http://www.bikeforums.net/showthread.php/390107-My-new-LED-headlight-and-USB-dynamo-circuit.
Although this is for a bicycle, the circuit will be the same, you'll just need the correct number of LEDs and dropper resistors.
Aug 15, 2011. 2:04 AMwobbler says:
Great Instructible and a professional final result.
Only comment is in reference to (6000mcd = 6 candela = 6 lumens). Candela and lumens are different and there is no direct link between them. They are not equal. Lumens measure the total light output, candelas measure the light per unit of angle, so two LEDs with the same lumens can have different candelas due to having different beam angles. Candelas will more effectively measure the brightness within the beam., If however you are comparing two different LEDs with different beam angles, you can go to the following page to use a calculator to calculate the apparent beam brightnesses in candelas from lumens:
http://led.linear1.org/lumen.wiz
or here:
http://led.linear1.org/how-do-i-convert-between-candelas-and-lumens/
Mar 31, 2011. 1:22 AMCHAMPt says:
Have always wanted to do this, and this filled in pretty much all the gaps I had to figure out a good plan of action. Good explaination and write-up!
Mar 25, 2011. 11:44 PMpufftmd2389 says:
nice.. i can see the last time you have replied here was about a year ago but still, like the idea and still cant find any LED motorcycle headlights anywhere easily so i am making my own.
plan on using one of these, hopefully it will work out well.
http://ledsupply.com/creexml-w280.php
Mar 24, 2011. 11:52 AM-Syrus- says:
Thanks a bunch!
Great piece of engineering, simple but effective.
Dec 11, 2010. 5:09 PMmrlunna13 says:
I bought 250 Super White LED's for 10.00 USD on eBay. They were from China but absolutely cheap and work great, plus you can buy ANY color in the rainbow.
I did a head light and turn signals for my motorized bicycle.
Great instructable.
Jesse
Dec 3, 2010. 11:27 AMdolulob says:
You did put it in your disclaimer, but I would once again like to point out, that this is highly illegal in pretty much every country!
Dec 3, 2010. 2:39 AMCalorie says:
This is cool, and I have thought about it in the past. I use to have a Honda C70 Passport. The headlights were anemic to be mild. I thought about somehow substituting in LEDs but never gathered the courage.
There is know an after-market stator which produces 90 watts!
If I could I would of installed flamethrowers instead of LEDs, but such is life. Nice Job.
Jan 15, 2010. 2:39 AMJayvis Vineet Gonsalves says:
Hello CaptainSlug, can I use a 100 5mm LED array to produce a beam of 1500 lumens? Where I live we do not get any Crees or Rebels. And will I get the same distance with the 5mm LEDs as I will get with the Cree?
Dec 31, 2009. 12:24 AMJayvis Vineet Gonsalves says:
How many meters ahead can you see with the led Headlights?
Dec 28, 2009. 12:38 AMJayvis Vineet Gonsalves says:
Thank you : )
Dec 27, 2009. 7:34 AMJayvis Vineet Gonsalves says:
But could you please upload the photo of the led head lamps brightening the road. Please : )
Dec 25, 2009. 12:39 AMJayvis Vineet Gonsalves says:
Great instructable!! Does your high beam illuminate the entire road ahead?
Could you please upload an image of the headlights illuminating the road. So that I can understand the power of these little LEDs. Thanx in advance.By the way Merry Christmas
Sep 1, 2009. 3:01 PMSwaggeringPagan says:
Great looking 'ible! How's the projection with the LEDs versus the regular bulb?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:CaptainSlug
