Also none of them offered output levels that were comparable to or better than the bulb I was trying to replace.
So I shopped around and decided to make my own. The approach I took was probably more complicated than what most of you will actually need, but since I put both available options in one headlight I can explain how to implement both.
DISCLAIMER
LED headlights are not DOT approved, so use at your own risk. The one I made was installed on an electric moped.
This guide assumes you will be using an input voltage between 12 and 14 volts. If you are using a different input voltage or LEDs of different ratings than what is indicated in this write-up you should use an LED Calculator to determine what resistors you need to use.
I would recommend this LED Calculator
The cost of this project ranges from $15 to $65 depending on whether you are making a new headlight from scratch, or adapting an existing fixture to use LEDs. This is primarily meant to be an introduction and overview of the options available for making an LED-only headlight.
Remove these ads by
Signing UpStep 1Part 1: LED Array Running Light
To calculate the potential output of the array you are going to make take the rating of the LEDs (6000mcd = 6 candela = 6 lumens) then multiply by the number of LEDs you intend to use.
I used 20 of the 6 lumen LEDs, so 20 x 6 means my output is approximately 120 lumens.
If you want more intensity it's best to start by using LEDs of a higher rating. Also keep in mind that even 6,000mcd LEDs will be painful to look at directly in the dark and will need to be diffused somewhat.
You can diffuse LEDs
1. by sanding their lenses with 600 grit sand paper
2. by making a soft diffusor sheet out of 1/16th or 1/8th inch clear or tinted acrylic or polycarbonate and then sanding it with 600 grit sand paper
3. by making a heavy diffusor plate out of 1/16th or 1/8th inch thickness white polyethylene sheet
Part 1 Supplies
1. Headlight fixture
2. Thin Polycarbonate or other suitable plastic sheet
3. Bulk lot of 50 to 100 white LEDs in 6000mcd or higher
You can order these cheaply from Chi-Wing LED Product Shop
4. Resistors (180ohm 1/4w for 13.4v max input or 220ohm 1/4w for 14v max input)
5. 22ga Wire
6. Pack of full sheet label paper
Part 1 Tools
1. 45w+ Soldering iron
2. Wire cutters
3. Power drill
4. Tin snips, band saw, or scroll saw (tool for cutting thin plastic)
5. Super glue
6. Hot Glue (optional)
7. Scissors
Im Ned from Manila, just want to know if this would work on my scooter if my headlight is running on AC not DC?
http://www.maplin.co.uk/bridge-rectifiers-19088
You would connect the alternator to the two AC symbols (doesn't matter which way round) then the rectifier would provide DC +/- on the other two terminals.
Then you can run your scooter and measure the DC voltage on the outputs and then calculate the number of diodes and resistor values as shown here by Captain Slug.
There is a rough idea of how to do it here:
http://www.bikeforums.net/showthread.php/390107-My-new-LED-headlight-and-USB-dynamo-circuit.
Although this is for a bicycle, the circuit will be the same, you'll just need the correct number of LEDs and dropper resistors.
Only comment is in reference to (6000mcd = 6 candela = 6 lumens). Candela and lumens are different and there is no direct link between them. They are not equal. Lumens measure the total light output, candelas measure the light per unit of angle, so two LEDs with the same lumens can have different candelas due to having different beam angles. Candelas will more effectively measure the brightness within the beam., If however you are comparing two different LEDs with different beam angles, you can go to the following page to use a calculator to calculate the apparent beam brightnesses in candelas from lumens:
http://led.linear1.org/lumen.wiz
or here:
http://led.linear1.org/how-do-i-convert-between-candelas-and-lumens/
plan on using one of these, hopefully it will work out well.
http://ledsupply.com/creexml-w280.php
Great piece of engineering, simple but effective.
I did a head light and turn signals for my motorized bicycle.
Great instructable.
Jesse
There is know an after-market stator which produces 90 watts!
If I could I would of installed flamethrowers instead of LEDs, but such is life. Nice Job.
http://www.visionxusa.com/led/
http://www.captainslug.com/temp/ledhl_18.jpg
Could you please upload an image of the headlights illuminating the road. So that I can understand the power of these little LEDs. Thanx in advance.By the way Merry Christmas
http://www.projectresponder.com/pse/d304-Solstice-Solo-10w-LED-Light-Euro.htm
The unit I made in my instructable would still be fairly useful for a bicycle, but just can't match the output of an 800 lumen unit.
