Now this thing freaking syncs to bass and treble beautifully after i remade it, like it was not awesome nuff. Also upped the quality of this instructable
Short video included of what this does
Blue LEDS that pulse to music, respond extremely well to bass, turn any place into a disco/dance floor :)
[THERE has been an issue in reordering steps]
dont worry about the picture, i actually made another one (based on your comments) and stuffed it inside for twice the awesomeness
watch?v=U_qD_JQkNlI64 KB
Remove these ads by
Signing UpStep 1You will Need
Amplifier: 1 channel
LEDS: many ($10 worth)
NPN Transistor
LM340 voltage regulator
Soldering iron
Other stuffs:
Computer with music
Soldering equipment
Wires
Do you know what's wrong?
> left as well as right channels blinking similarly
> not enough intensity of leds even on full volume on laptop
> what is exactly a amp. how does it looks like since i kwn that amp=amplifier and its too big like 2feet by 1feet
and forgot to say that i tried using with a resistor and without but only got weaker with resistor.
First of all, the resistor is needed, because (from what ive understood)the LED does not put a load on the power supply, so the supply, the voltage regulator will give as high an amperage as possible, until it burns out the LED.
Finally, the reason it is probably not working well is that the electric signal coming directly out of your mic is very weak, and so it is being amplified, but is so low that not much is getting amplified.
(say that the transistor has a gain of 20 (gain= by how much the input voltage is multiplied by to get the output voltage) if you put in 0.5 volts, it will give out 10 volts. However, if the input is only 0.1 volts, it will only give out 2 volts. I think that is the problem with your set-up.
the direct speaker output line or the audio signal line... ???
1. Do you really need a voltage regulator?
2. If you dont can I use this transistor: BC547C
Awesome I'ble! been wanting to do this for the *longest* of time...
Its a little hard to read your schematic, you could try using a free CAD program like Egale to draw the circuit.
other than that verry good instructable I liked it alot. **** :)
well i cant buy a transistor online so i found the web site of a electronics shop (similar to radio-shack) near my house and was wondering if this one would work in this circuit.
TIP 31B/C Power Transistor NPN
http://www.dse.com.au/cgi-bin/dse.storefront/4a6a8c36125db5042740c0a87e01067e/Product/View/Z2020
please reply asap
thx every one :D
