This instructable will show you how you can use some LEDs to light up your photos.
Remove these ads by
Signing UpStep 1Materials & Tools
- Photo frame (I used a metal frame, bought it for only $1).
- 8x 5mm LEDs (You can use colored ones also if you like. Or give your white LEDs a color)
- Electric wire
- Button Cell 3v Battery (CR2032)
- Button Cell Holder
- Foam (actually you can use allot for this, even cardboard)
- Hobby Blade
- Hot Glue (glue gun)
So maybe a photocell switch would be cool?
Switch it on only when the light in the room are off, for maximum battery life.
I used a button cell because there isn't much space behind the frame to work with. If you're going to let the photo frame stand up on a table, then you can put a D or C cell behind it.
But if you'd like to hang it on the wall, a button cell is the only way to go.
I'll check the local theaters to see if one closes down soon so I can make one myself too :)
How long does those batterys last?
Canone use silicone instead of a glue gun or will the silicone
take to long to dry
Drie
Also i'm not sure how long 1 cr2032 battery will last. Haha, i'm not much of a help am I :)
I think the battery will last at least a couple of weeks (if you leave it on the whole time).
You can put a switch on it and turn it only on at night.
Or you can put like 5 batteries in there (parallel), then you do like 10 weeks with it leaving it on :)
Thanks for posting this!
They are 5mm white 20.000mcd. I bought 100 pcs for only $7.
If I were to do this I would use a Wall Wart instead of the CR2032.
This frame was only $1 so I was not able to do much more with the backside because of the space. Next frame i'm going to buy will have a thicker frame so I can work more on the backside.
L
