LED Photography Light
8,255
77
15
Posted
Introduction: LED Photography Light
Hey everyone, in this instructable I will show you how to make an LED light for photography. It can optionally be controlled by a smartphone.
Step 1: Parts and Tools
Here are the parts and tools that you will need to make this project:
Parts:
Ultrabright white 5mm LEDs (x6)
Linkit ONE board with WiFi antenna
Acrylic (3mm)
2n2222a NPN transistor
1k ohm resistor
Tools:
Computer with the latest version of the arduino IDE and linkit ONE drivers
Bandsaw
Desktop printer (for template)
Soldering iron and solder
Hot glue gun and hot glue
Step 2: Cut Out Template
Using a desktop printer, print the attached template. Then, cut it out on a bandsaw. Cut out the "bottom" piece in either translucent white or clear acrylic. I chose white.
Step 3: Glue Enclosure Together
Glue the long rectangular side pieces to the smaller side pieces at a 90 degree angles. Then, add glue the second long rectangular side piece to make one big hollow rectangle. Now, glue the white or clear piece to the bottom of the hollow rectangle. Don't glue the remaining top piece on yet.
Step 4: Glue LEDs
Hot glue the LEDs to the box, one in each corner and one at the middle of each side piece.
Step 5: Wiring
Use the wiring diagram to solder all electronic components together.
Also, you will need to attach the WiFi antenna. Do so by flipping over the Linkit ONE board and plugging the small uFL connector to the connector that says "WiFi/ BT ANT".
Step 6: Code
Download the (1st) attached code, open it, and modify the line that says: "#define WIFI_AP "Your Network"" by changing out "Your Network" to the name of your WiFi network. Do the same for the next line, only you will type in the network password this time. Now, upload the code to the board. Once that is done, open the serial monitor and copy the first IP address shown.
Now, download and open the 2nd attached code and change out the same two lines as last time. Then press upload.
Step 7: Testing...
To test the light,
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
15 Comments
I like the idea but 6 of these LED's are just really weak...
I've just finished making a 200W Variable Spectrum LED Panel as a photography light, And I'll be uploading how to make it in a couple of days!
look forward to seeing your light
I've uploaded SpectrumLED! This is the link
Thanks, I'm doing a "marathon" of making the Instructable
I'll do my best to upload it until Saturday (It's ~30 Steps!)
I replied to your reply - it wasn't a question. :P
Yeah, I just had some LEDs laying around and decided to make a lower powered one. I'll make sure to see your instructable!
Useful light-box.
Lower powered light-boxes like these are brilliant for close-up work or for transferring old large-format negatives to digital.
Sometimes, less power is just what you need.
Well, That's where Joel S. Spira comes in, He invented the dimmer!
