LED Ping Pong Ball (Improved)
This is basically the same design, but I made it more neater and it looks much better!!
This is the old: http://www.instructables.com/id/LED-Ball/
Step 1Tools
Tools
You will need the following:
1. Drill
2. Drill Bits
3. Scissors
4. Duct Tape
29 comments
Dec 5, 2010. 6:24 PMKapower says:
I havent made it yet, but can u still use it to play ping pong?
Nov 18, 2010. 12:07 PMMadScientist101 says:
the glowing looks like its radioactive lol
Feb 20, 2010. 8:19 AMcherishcherub says:
 use a knife to cut a slit half way (on the  line)and you can open it up big enough for the throwie to fit in and with it closes up, theres only a ting gap!
Feb 14, 2010. 9:02 AMtwonkie12 says:
to get it bouncy you could dut the hole so it can fit like a puzzle peice and then glue or tape it back on. i think tape would work better because it is light weight and can spread evenly without having to snad it down with sand paper.
Sep 13, 2008. 9:52 PMM F says:
I want a way to close the hole in the ball . so that it will bounce. maybe fill the ball with the throwie and some plastic wrap? I find that plastic wrap works well to diffuse light evenly, just crumple it up. Any better ideas to close the hole?
Sep 13, 2008. 9:53 PMM F says:
using the plastic wrap to hold the throwie while it bounces. think it will work?
Oct 24, 2008. 1:08 PMcowscankill says:
Hmm... I thought ping pong balls bounced because there was some air in them... It might work.
Oct 12, 2009. 9:14 AMbassclarinet23 says:
Look up the instructable for LED bouncies...somewhat similar to this one, just bouncy!
Nov 3, 2008. 12:36 AMawaite says:
Can sum 1 think of a way to turn off the led?
Oct 12, 2009. 9:13 AMbassclarinet23 says:
They make impact switches. That's how kiddie light up shoes work...you could look into that.
Sep 27, 2008. 10:46 AMlizardfreedom says:
whats a LED throwie
Oct 12, 2009. 9:12 AMbassclarinet23 says:
It's basically an LED, batteries, and a magnet. You throw them on some metal surface (where the magnet will stick) and it looks really cool, especially if you put a lot of them in one public place.
Oct 24, 2008. 1:07 PMcowscankill says:
OMG! It's the most popular Instructable on this site!
LED Throwie (This is the link: http://www.instructables.com/id/LED-Throwies/)
Nov 22, 2008. 11:43 AMskidude28 says:
My instructable is the most popular one on the site!
Jul 24, 2009. 1:12 PMcryophile says:
If you could somehow add a vibration sensor to the ball and use tri-color LEDs, that would be awesome! Every time the ball hit a hard surface, it would change color!
Oct 12, 2009. 9:09 AMbassclarinet23 says:
Get a switch from those kiddie light up shoes. That could work.
Jul 24, 2009. 9:04 AMScar16 says:
add a switch
Jul 21, 2009. 4:30 PMLance Mt. says:
Hehehehehehe, Even sweetier man
May 19, 2009. 5:08 PMshaneomacmcgee says:
How big is that? Dime-sized? 1/4 inch? thanks
May 19, 2009. 8:49 PMshaneomacmcgee says:
Thanks, helped a lot
Apr 26, 2009. 9:34 PMtterraj123 says:
heres what i did and it can turn off and works with ping pong cut it directly in half so its even then put the LED throwie in it (i put 2 for a cool effect) then just tape on the seam then to turn off take off the tape :)
Aug 14, 2008. 12:38 PMtudgeanator says:
sweeeeeeeeeeeeeet! You could use these for light-up poi if you glued on a string/chain before adding the balloon!
Nov 29, 2008. 8:03 PMsaxophones says:
What's a poi????
Aug 22, 2008. 1:30 PMtudgeanator says:
No problem.I would do it myself but i have allready bought some light-up poi. I think you would need to weight the ping pong balls before using them as poi.
Oct 6, 2008. 10:07 AMchuckr44 says:
Why not make a 3 sided flap in the PPB, bend it outwards, insert LED throwie, then bend flap back in place? Glue or tape flap.
Jun 17, 2008. 6:36 PMItsgoofytime says:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:dcmania21
