3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Plant Growth Light
My LED plant growth light has been an effort in my new found hobby; gardening.
I have been extremely intrigued by the whole urban gardening movement, and my
dream is to help bring it indoors. So here is the part of my efforts that involves LED's.
Step 1Tools & Materials
Tools & Materials
(A) Soldering Iron
(B) Cutting pliers
(C) Breadboard
(1) LED's, lots of them. (Ive been using these: white, blue, and red ones.)
(2) Resistors ( I have changed resistance as needed.)
(3) Solder
(4) Wire
(5) Circuit boards (Size depends on how many LED's you want use.)
(6) Power supply components
(7) Spray on Insulation (Optional)
Add some patience and imagination, and you'll be one your way to create something
 awesome with your own two hands.
P.S. Don't forget a hammer and some elbow grease to get you out of the tough spots.
44 comments
1-40 of 44next »
Jul 18, 2011. 4:00 AMdiscovery2011 says:
(removed by author or community request)
Feb 5, 2012. 10:14 PMhanlin_y says:
I understand that we have to be careful around electricity. When electricity is near water, you should plug it into GFCI outlets. If your indoor garden does not have GFCI outlets, you can get GFCI extension cords. Depending on how hot your LED's run, it is not a bad idea to add a tip over sensor so it turns off when it falls over.
I really want an LED grow light too. I just ordered some 3W royal blue and deep red LED's. To make it simple, you can use flexible clamp lamps for LED's that fit standard fixtures but this method is bulkier and more expense is needed.
Sep 26, 2011. 6:16 PMjexter says:
Are you sure you're clear on the concept of www.instructables.com ? Because I think you may be more at home at www.wherecanibuyoverpricedcrapicould buildbetterandcheapermyself.com.
Just sayin...  ;-)
Aug 15, 2011. 8:30 PMCidlyLydia says:
good, you have a great yield
Apr 26, 2011. 10:42 AMarnookie says:
If you are thinking of building a diy grow light please take note of this.
Each and every led needs to be atleast 1watt each. Anything below that will be useless so don't use old leds out of toys or old boards, they simply will have too little Total lumens versus lumens per watt. You need atleast 10mm LEDs with 1watt per LED to supply enough light to the plant anything lower will not work. A good combination is a pannel made from 75% 1watt red high brightness leds, 20% 1watt blue high brightness leds and 5% 1watt amber high brightness leds. somewhere in the region of 660nm for red and 460nm for blue
There is also no effective difference in penetrative power for horticultural purposes between a 1W LED and a 3W LED. So anything over 1watt is just wasted. This means brightness has very little to do with the benefit you will get once you use 1wat leds. Don't confuse this with a pannel made from say 20 LEDs rated a 10watt as to one with 10 LEDs rated at 10watt. As the 20 watt pannel will use the useless 0.5watt leds verses the 10watt pannel that uses 10x10watt 1watt LEDs that are ideal. This has been tested and proven that 1watt single LEDs have great benefit to plants and anything less is just a waste of time and has no benefit at all to plants. The same applies with going brighter than 1watt has no benefit either.
Hope that may help some of you. Especially if you are growing indoors.
Also LEDs are more efficient than any other form of grow lighting available.
The commercially available LED growlights outperform all other growlamps from HID lamps to including high pressure sodium (HPS) and metal halide (MH) lamps.
So prepare to see other grow lamps become obsolete as LED growlight take over.
Jan 8, 2011. 7:25 PMmr_man says:
Good Job! If my tone sounds critical, I apologize in advance. I just want to share some information with whomever might read this. This is just free information.
If I build a LED grow-light I will do a few things differently. For anyone considering a similar project, here's what I would recommend:
1. The most common Red LED is made of GaAs and has a wavelength of 625 nm. This isn't bad, but it isn't ideal for plants. A "super-Red" or "deep-red" LED emitting a wavelength of 660 nm is better (FYI the LED material will have "Al' or "P" in addition to the "GaAs") . These are harder to find, and may cost a bit more, but in theory they are worth the trouble to obtain. Order from a site like digikey.com or mouser.com or even superbrightleds.com where they actually list the wavelength and other useful spec's.
2. Use high-brightness LEDs that can handle at least 700mA to 1 Amp of current or more, because they put out a lot more light for the money.
A note on heat... Make sure the thermal pad on the LED is *soldered* to a copper heat spreader that you have first tinned with solder. For a surface-mount part, you will have to use a hot-plate or frying pan, or hot-air gun, or oven to reflow the solder. The Cree website has pdf documents on how to do this. It is often easier to just buy high-brightness LEDs that come pre-mounted on a hexagonal "star"-shaped circuit board with mounting holes and everything. These typically have an aluminum core, which makes an excellent heat spreader, so then you only have to put heat-sink compound on the back of it and screw it down to a heat-sink, or you can just epoxy the whole thing down semi-permanently.
2. Use a higher voltage power supply, like 12 or better yet 24 volts. This allows you to put more LEDs in series. Since so you can always guarantee that all LEDs in the string are carrying the same current, less resistors are needed. The whole thing will be more efficient, and produce less heat, and keep your electric bill down.
4. The voltage regulator probably isn't necessary, even if your power supply is "unregulated". You can probably get away with using smaller resistors if you just add up the voltages of all the LEDs in a given string, and adjust the number of LEDs per string to get as close as possible to the power supply voltage. To do this it helps to mix and match LED colors in the string, just make sure that you don't exceed the LED's current rating. Ohm's law says that the resistor value in ohms that you should use is:
R = (Vs - V_LED) / I_LED
Where Vs is the power supply voltage,
V_LED is the sum of the LED voltages in the string, and
I_LED is the current in amps that the LEDs are rated for
If V_LED is just slightly less than Vs then you will only need a very low value resistor, like 1 ohm or less, assuming a 1 amp string. You shouldn't need to drop more than a volt or so across the resistor. If you're dropping over 2 volts, why not just add another LED instead?
Just calculate the proper resistor value for each string, and after you've built the circuit, measure the current through each string with an ammeter to make sure the current does not exceed the LED's spec.
I hope this helps. When I get organized enough to build a light-source and take photos, I'll try to put together an 'ible.
Sep 7, 2010. 7:27 AM5Volt says:
I suspect that all those capacitor in series with the supplies (both at the "in" and the "out" of the regulator) will prevent the circuit to work : you probably want to mount them in parallel, from the pins to ground.
The diode also seems to be reversed.
Three white LEDs can be powered from 9V directly witha few Ohm resistor in series (220 seems a lot). The same for blue LEDs.
Also, same type LEDs seems to receive different current...
I suspect your schematic needs some clean up !
Ciao
5volt
Sep 10, 2010. 2:08 PMmsuzuki777 says:
I think you did a great job with this Instructable. What matters is that you got it to work and made the effort to do an Instructable. Reading schematics is hard, creating your own is even harder.
Your first schematic wouldn't have caused any harm but wouldn't have worked. Unfortunately, the second one would probably work but isn't quite correct. I am a little surprised that Adafruit didn't have a schematic with the kit.
I've included a schematic I clipped out of a Freeduino that shows how the capacitors should be drawn. For the two capacitors on the left, each one is tied to the input and to ground. The same goes with the two on the right.
Incidentally, the larger capacitors are used to filter out low frequency noise and the smaller capacitors filter out higher frequency noise. With a 9 volt battery, there is basically no noise at all so those caps aren't necessary. On the output side, there's only LEDs so again the caps aren't doing much.
By the way, if your 7805 gets pretty hot you can add a heatsink. That's what the little hole is for. You can bolt on a heatsink from Radio Shack or make your own from a piece of metal
Keep up the good work.
L.O.G.
Sep 15, 2010. 6:12 PMmsuzuki777 says:
I'm glad I could help. Many people have trouble going from schematics to wiring components and vice versa. I've worked in the electronics/computer field for 25 years so it's pretty easy for me.
I'm planning on making some Instructables on basic electronics for the Arduino, I hope I can get them done.
It's easy to find your web page. Just go to Instructables.com and type in
in the search box.
L.O.G.
Sep 9, 2010. 6:32 AMShiftlock says:
You can't just draw up a schematic that's wrong and say "I wasn't sure how to draw that." Someone could spend a lot of time and effort mocking up that schematic. If it doesn't accurately represent the circuit you're intending it to, then please REMOVE IT, before someone wastes a lot of effort actually USING it. What good is it if it's not right, anyway? Just for show? Come on! Either fix it, remove it, or at the very least add a disclaimer saying that it's WRONG and shouldn't be followed!
Sep 9, 2010. 8:38 AMShiftlock says:
That's fine, but the whole point of creating an instructable is that people will be following YOU and your instructions, not instructions on another site. If your instructions are wrong, including the schematics you post, then you are leading people into making a mistake. Faulty schematics are not a help to anyone. I'm sure you understand that.
Sep 9, 2010. 2:03 PMSwaggeringPagan says:
Well, why don't YOU show us how to draw the proper schematic?
Sep 9, 2010. 3:16 PMShiftlock says:
I don't have to, because I didn't write the instructable. That said, it's an easy fix, and if I had the time I WOULD fix it. The capacitors are supposed to be in parallel, not series. The point is, he's aware that the schematic is wrong, so he should either fix it, or remove it, before it causes a problem for someone who relies on it to build the circuit. Can't you see why this is a problem? In fact, when dealing with electrical circuits, a mistaken schematic could cause a serious safety hazard. In this case the voltage/current is low, so the worst-case scenario is that someone's time and effort is wasted, but still...
Sep 9, 2010. 4:44 PMSwaggeringPagan says:
...you have time to peck out a longish reply here.......
Sep 9, 2010. 5:29 PMShiftlock says:
I type fast.
Sep 9, 2010. 8:30 PMjackoftheforest says:
Hahaha. Great thread.
Sep 15, 2010. 3:30 AMverdastel says:
Hehehehehe
Sep 15, 2010. 3:35 AMverdastel says:
Good instructable...and i admire your equanimity in handling the criticism
Sep 9, 2010. 6:33 AMBeta_Orionis says:
Are you familiar with wire-wrapping? It's a very clean solution to soldering across generic pc boards and much easier to fix later (swap out dead LEDs etc.)
Sep 11, 2010. 7:01 PMBeta_Orionis says:
No problem! Enjoy. :)
Sep 6, 2010. 10:42 PMOwlbear says:
my question is... how do you get enough UV from LEDs? most plant lights are specifically meant o deliver more UV than normal lighting.
Sep 11, 2010. 1:21 AMExitao says:
I was wondering about the need for UV myself.
They do make "UV" LEDs, BTW... I have a tiny LED flashlight intended for checking currency.
Sep 9, 2010. 3:36 PMml4d3n says:
Hi friend, I am very curious about this tehnique, and want to know if this is used only overnight, and does the plant need some time in the dark?? And also, why did you use this color combination? Is it the best for the pant or you just like it?
Sep 10, 2010. 7:29 AMjimmiek says:
I don't see the schematic all the 'electronics experts' are complaining about. The reason I ask about this is that I'm an electronics iggnoramus, so I'd like to do this thing right ;) I've been wanting to find a good schematic for doing LEDs for my aquaponics system. I guess you have to go PRO to get the schematic, huh? I'm too poor and too cheap to go PRO!
Sep 10, 2010. 9:28 AMNate Ocean says:
Yeah, this is becoming a chronic problem with Instructables...most of them are "crippled" with the constant "nags" to upgrade to PRO.
What a shame, it used to be a nice web site. Some of the stuff lately is just incompetent junk.
Sep 9, 2010. 1:12 PMadamlight says:
I had looked in to this a while back. From what i remember, you should have more red LEDs than blue. A ratio of around 3 or 4 red to 1 blue is good for most plants. Different plants will need different mixes of light. I never read anything about mixing in other colors or white. Also, 10-25 watts per square foot was recommended to really get things growing. You do need more light to grow fruit and veggies.
Sep 9, 2010. 11:10 AMkea says:
On LEDS.
For some reason White LEDS have a shorter life than other colours.
I would use self adhesive LED light strips ,these have the resistors built in.
Wire them in parrell.
Also different coloured LEDS have different voltage drops.
Cheers Kiwi John M
Sep 9, 2010. 8:17 AMmacrumpton says:
I was wondering if just getting a couple of strings of LED Xmas lights might be a readymade alternative to this.
I have seen strings of 100 LEDs of various single colors as well as mixed colors on ebay for $6.50 including shipping like these:
http://cgi.ebay.com/10M-100-LED-String-Lights-Christmas-party-Fairy-Blue-/360298929269?pt=LH_DefaultDomain_0&hash=item53e37d5c75
To make the LEDs point in the same direction a piece of thin plywood or even cardboard with holes big enough to stick the LED sockets through would seem to be ideal. The cardboard option would let you easily make a curved panel with the LEDs pointing inward toward the plant for light from all directions.
Sep 9, 2010. 6:58 AMSaprobic says:
I have been growing plants with some LED arrays I made for a while now and don't let the theory confound the practice. Although by the textbook you will only need red and blue each plant is different and they do use the whole spectrum for various queues. You will find that with a heavy blue load you will get good vegetative growth and poor flowering. More red will increase flowering yet in both of these cases most plants will produce poor fruit. I started to get some better results by adding in some amber (The intent was to stimulate beta caroten production). I was going to add some white next to see if some other secondary metabolite production or growth queues might change.
Also I found I have much better success once I enclosed the growth chamber and covering all interior surfaces in reflective or white background.
Sep 8, 2010. 8:54 PMtubesman says:
I hope your White LED's are there so your plants look pretty. They are not worth much for photosynthesis. Plants only use Red and Blue.
Sep 6, 2010. 5:55 AMfegundez1 says:
Why use white? Your plants will make the most of red, blue, and some orange lighting. Most important is air! It would seem obvious but this part is what has killed more seedlings than any other thing, at least in my experience. I have been using LED for seedling and small plant/ clone light for a few years now and I have found that long days and air,air say it again air! is what keeps it good of course, you also need to monitor the water as with a breeze going on there will be a little evaporation. I use a pc fan in an area like the one you have there and it works fine. I have cloned a lot of rare plants for my mom who is out to save the world from plant extinction and this is a great way to do it. Good luck with your gardening.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Pjpuas(Click me!)
Hey there! I'm an industrious technological hippie. It may sound like an oxymoron, but really its not. I am an overtly curious tinkerer, so I love all kinds of technology. But I also have an immense r...
more »
