GOLFIE!
2,839
4
8
Published
Introduction: GOLFIE!
About: I like to make stuff... thats why I'm here I guess
LED Practice Golf Ball. My first instructable for the LED challenge. For all those golfers who just love to practice, they can now practice at night
Step 1: Materials
You will need practice a golf ball (duh) you can find these at wal-mart and there not to expensive, a cutting tool (i used a knife), a battery, a LED, and some electrical tape.
Step 2: Making the Incision
cut a hole in the ball that will fit your battery and light but will not let them get out. (Or if you want cut the ball cleanly in half and use glue to put it back together)
Step 3: LET THERE BE LIGHT!
combine the battery and LED then used the electrical tape to keep them connected
Step 4: Combine the 2
put the light into the ball and make sure it doesn't fall out. I advise using the knife to pry the cut open to slip the light in just don't cut yourself!
Step 5: Play Ball
Now your done and ready to go! keep in mind that practice golf balls are not ment to go far and the eventually the battery will burn out the LED.
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    8 Comments
    First there was the Throwie, then the floatie and the sinkie and the ice floatie and the jigglie, now there's the golfie! (How about adding a switch so that the battery lasts linger?)
    I love linger lasting batteries :P Come to think of it, I just love batteries in general. I like the idea of calling it a Golfie too.
    >doh< Oh, for an edit function...
    thanks for spell Checking and nice idea with the name!
    Same, it would make life so much easier...
    Good idea, but I don't like the way it was done. Maybe cut the ball cleanly and glue it back together with a strong glue or something? Because with the huge slit, when the ball is hit it would collapse upon it self a little bit, causing the ball to not go as far. And it would probably eventually break.
    Good idea, i didn't happen with me during test rounds but i'm sure a for serious golfer could do that, i'll add in a side note for yeah. its just that i wanted things simple, and glue and I aren't the best of friends
    This is actually a very good idea. But, I would add in a resistor, and a switch (connected to the LED part) so then I can take it out whenever I want, and it won't burn out, but this is a good idea! Very nice job. +1 rating. (added to favorites)
